why dosent this make sence on Sportmax 002's and a +0 offset with out tires sticking out !!! check i
Old Mar 14, 2008 | 09:26 PM
94EJ1Coupe's Avatar
Default why dosent this make sence on Sportmax 002's and a +0 offset with out tires sticking out !!! check i
hey everyone!! well just wanted to see if anyone has a good answer for this question. why is it that this picture of this DA with 002's dont stick out like everyone elses, not to say Civic's but DA's as well? any suggestions? I originally wanted to buy these wheels. had to stick with 501 which has a +15 offset instead of +0........
Old Mar 14, 2008 | 09:42 PM
97ekb18b's Avatar
Default Re: why dosent this make sence on Sportmax 002's and a +0 offset with out tires sticking out !!! che
spacers.!.!.!.!
Old Mar 14, 2008 | 09:54 PM
94EJ1Coupe's Avatar
what you mean how ??? wouldent this make it worst of the situation of +0 offset. or you mean spacers will make your tire stick out like this....... I thought this was +0 offset ?????
Old Mar 14, 2008 | 10:03 PM
94EJ1Coupe's Avatar
Default Re: (94EJ1Coupe)
THIS IS WHAT I THOUGHT +0 OFFSET WAS ON A CIVIC OR INTEGRA BUT I GUESS THEY ARE BOTH USING SPACERS RIGHT??????
Old Mar 14, 2008 | 10:10 PM
EG-Kaos's Avatar
very thin tire with negative camber
Old Mar 14, 2008 | 10:14 PM
94EJ1Coupe's Avatar
dang!!! negative camber? wount that make your inter side of the tires wear out faster??
Old Mar 14, 2008 | 10:18 PM
EG-Kaos's Avatar
yup at the cost of lookin "okay" im not a big fan of 0 offset honda's
Old Mar 14, 2008 | 10:23 PM
94EJ1Coupe's Avatar
Default Re: (EG-Kaos)
i just got the 501's with +15 offset, hope they dont stick out as much when i get them hooked on my car ! guess ill just roll back the fenders and pray!
Old Mar 15, 2008 | 05:48 AM
stock99si's Avatar
the white pic u showed of the DA has aftermarket fenders.
Old Mar 17, 2008 | 03:14 PM
boostek9's Avatar
no spacers, that would make them sit even further out. camber is the key, if you can handle tire wear!
Old Mar 17, 2008 | 03:40 PM
user 98292739's Avatar
negative camber doesnt wear out tires that much faster....
as long as yoru toe is set you will only cut a thousand or two miles off the total milage.
i ride slammed with negative 3.5 camber and my tires wear even for the past 3 years.
Old Mar 17, 2008 | 03:43 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: (boostek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostek9 &raquo;</TD></TR><TR><TD CLASS="quote">no spacers, that would make them sit even further out. camber is the key, if you can handle tire wear!</TD></TR></TABLE>
thank you. this is correct, some of you need a lesson in offset..
juni da9
Jul 2, 2009 03:45 PM
thisguyhere
Honda Civic (2001 - 2005)
16
Jun 11, 2009 08:15 AM
ACTION JACTION
Aug 24, 2008 10:01 AM
MikeFabRex
Jan 8, 2007 06:54 AM
