Update on Rear Brace
https://honda-tech.com/zerothread?id=2139492
This thread has been locked, so here is the update that was asked for!
Been running the brace for 2 months now and no issues. I was amazed at how much the ride changed after install. I have changed my agx's from a 1 to a 3 setting, I couldn't handle the abuse.
I drive 70 miles each day to commute to work, and have seen no issues associated. Everyone shoule make one of these!
Re: Update on Rear Brace (EG-Honda)
Did you also machine the rear reinforcement pieces that allow the stress to be spread out threw a larger surface are like the asr kit comes with? I think its useless without the back pieces.
Re: Update on Rear Brace (ejoner)
Did not make the bach pieces. The flat bar has proved plenty strong to take the load. I am a little different from the masses here, I don't autocross...I rallyX. I tested this on a day of hard trail riding with no signs of fatigue. The strength is in the LCA mounts, not in the weak sheetmetal. The only reason to mount them also to the rear blocks is if you plan on flex, but that's the whole reason for a tie bar isn't it, to eliminate flex?
do you still have some in stock? ive been following your posts man and it looks great. i also drive about the same distance to work everyday. so it wouldnt hurt
Gregmatic
10-10-2022 11:44 PM
essex
10
08-14-2008 03:15 PM
Razr2
03-23-2008 12:39 PM
