Anyone running with upper timing belt cover removed?
i think your avitar scared everyone away.......no I do not run with the cover removed. it is there for a reason
I had the upper cover removed for a while until a small rock or something got in there and threw my timing belt off. It took me forever to find the problem when my car was running like ***. You can hear your cam gears spinning a little bit with the cover off.
That's just great....
I just cut off the side so I can expose my cam gear. Well, good excuse to go out and get the OEM Red valve cover now
I pulled off the timing valve cover and the timing belt felt a little loose between the two cam gear
Sinner
Mar 24, 2008 08:43 AM
Ebony and Ivory
Jun 7, 2005 09:09 AM
Littleredsi
Jan 24, 2004 08:13 PM
