Can't detach shift linkage coupling from selector rod on tranny.
Old Jul 8, 2002 | 10:45 AM
cbpldc's Avatar
Default Can't detach shift linkage coupling from selector rod on tranny.
I have an 87 CRX Si with the stock engine and tranny. We droppe the tranny with the stick and everything still attached. I need to change the selector rod seal where it goes into the tranny, but I can't pull the shift linkage coupler off of there. I have removed the clip and the roll pin, but still can't seem to get that linkage coupler to come off.
Any ideas?
Am I missing something?
Thanks,
Chris
cbpldc's Avatar
Default Re: Can't detach shift linkage coupling from selector rod on tranny. (cbpldc)
And while I'm at it, I also have no idea how to replace the input shaft seal on the tranny.
Chris
Old Jul 8, 2002 | 04:17 PM
Chiovnidca's Avatar
Any ideas?
Thanks,
Chris
Sometimes they get rusted to the shaft. Some penatrating oil and a couple light taps with a hammer should loosen it up. (Don't bend the shaft.)
Old Jul 8, 2002 | 04:21 PM
Chiovnidca's Avatar
Chris
Unfortunatly on some Honda tranies, you have to replace that seal from the inside. Major dissassembly required. After you get the shift linkage and the rubber boot off you will know for sure.
Old Jul 10, 2002 | 03:28 AM
cbpldc's Avatar
Default Re: Can't detach shift linkage coupling from selector rod on tranny. (Chiovnidca)
You are correct! We disassembled the tranny last night according to the Haynes manual and labeled everything out on our bench with post it notes, so we can put it back together correctly. It only took us 30 min. to get down to the input shaft seal. It was definitely torn and it's easy to see how it could be at fault for getting oil on the clutch and soaking it.
If anyone is interested, I could take pictures and post them.
Thanks for the help.
Chris
Old Jul 10, 2002 | 09:16 AM
riceboy's Avatar
pics of the tranny dissasembly would be appreciated
Old Jul 11, 2002 | 04:05 AM
cbpldc's Avatar
Default Re: Can't detach shift linkage coupling from selector rod on tranny. (riceboy)
Once I can figure out how to get the images downloaded from my Camera. I'm a bit miffed it no longer wants to be detected via the USB cable anymore, from any computer.
We are getting the seal in from Nashville today and should have the car together by Friday or saturday. It should be a screamer. No cat, no muffler, fresh tuneup and 1800 lbs. Also has new timing belt, all oil seals replaced oil pan gasket, clutch etc.
I look forward to getting it out and thrashing it. I currently own a Dodge Stealth, and that thing runs like a scalded dog, but it's no fun because it gets up to triple digits and you just don't feel the speed. My little rex should be an absolute blast.
Chris
eg6206
Transmission & Drivetrain
10
Mar 4, 2012 11:03 AM
Egg-weezy
Dec 11, 2007 11:24 AM
Aespooncivic
May 7, 2005 09:23 PM
