What is the best way to wire a JL 12w3v2 sub?
Old Mar 14, 2008 | 06:00 PM
mikeycivic's Avatar
Default What is the best way to wire a JL 12w3v2 sub?
I have a JL 12w3v2 sub. Dual voice coil. What is the best way to wire it to get the loudest and best sound out of it? I will have it wired to a 500/1 JL amp. Thanks
Old Mar 14, 2008 | 06:17 PM
standbackimapro's Avatar
Default Re: What is the best way to wire a JL 12w3v2 sub? (mikeycivic)
Wire it in a parallell, which means Connect the + On one voice coil to the positive on the other voice coil, then the negative of one voice coil to the negative of the other voice coil
Old Mar 14, 2008 | 06:46 PM
2boysboostin's Avatar
yea what he said
Old Mar 14, 2008 | 08:30 PM
junkspeedproject's Avatar
depends. is your sub a dual 2, 4, or 8 ohm? the 500/1 JL amp puts out the same power if your sub is wired between 1.5 ohms-4 ohms.
heres the breakdown for you:
If your sub is the dual 2 ohm model- i would wire the sub into series. this would put your sub's impedance at 4 ohms.
If your sub is the dual 4 ohm model- i would wire the sub parallel. this would keep the sub's impedance at 2 ohms.
If your sub is the dual 8 ohm model- i would wire the sub parallel. this keeps it at 4 ohms impedance
just as long as the the impedance of the sub is between 1.5 and 4 ohms you should be good.
Modified by junkspeedproject at 9:48 PM 3/14/2008
Old Mar 15, 2008 | 05:37 AM
mikeycivic's Avatar
Default Re: (junkspeedproject)
its the dual 2 model
Old Mar 15, 2008 | 11:56 AM
fcm's Avatar
fcm
Old Fart
Default Re: (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">its the dual 2 model</TD></TR></TABLE> Series, connect the pos.(+) of one VC to the neg.(-) of the other VC, that will leave you with a pos.(+) and a neg.(-) to connect to the amp, no it makes no diff. which pos.(+) and neg.(-) you use as long as it's one from each VC.
Hint... try connecting the pos.(+) and neg.(-) to the amp both ways, [pos.(+) to pos.(+)/neg.(-) to neg.(-) and pos.(+) to neg.(-)/neg.(-) to pos.(+)] for phasing with the rest of the system, one of the two ways will sound better to you94
Old Mar 15, 2008 | 12:20 PM
mikeycivic's Avatar
Default Re: (fcm)
pmd
Old Mar 16, 2008 | 10:13 AM
fcm's Avatar
fcm
Old Fart
You have an IM.
Yes it was the correct way. 94
Old Mar 16, 2008 | 11:27 AM
Red Asphalt's Avatar
* B A N N E D *
Default Re: (fcm)
Old Mar 16, 2008 | 02:45 PM
mikeycivic's Avatar
Default Re: (fcm)
never got the im
Old Mar 17, 2008 | 06:13 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">never got the im</TD></TR></TABLE> You must have, you answered it. 94
Old Mar 17, 2008 | 12:00 PM
mikeycivic's Avatar
Default Re: (fcm)
i had to manually check
Old Mar 20, 2008 | 02:39 PM
chunty kevin's Avatar
youre gonna blow your sub with that amp, i hope the amp is turned down or wired to two subs.
Old Mar 20, 2008 | 02:42 PM
mikeycivic's Avatar
Default Re: (chunty kevin)
500/1 will not blow that sub dude
Old Mar 20, 2008 | 03:28 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunty kevin &raquo;</TD></TR><TR><TD CLASS="quote">youre gonna blow your sub with that amp, </TD></TR></TABLE> Why is that?
He has a 12W3v2-D2, a 300W DVC2 ohm wired in series for a 4 ohm load with a 1x500W RMS amp driving it, what he will have is lots of dynamic headroom.
He has a better chance of blowing s sub if he used that amp to drive two of them, as he would be under-powered by 100W.
It is better to be over-powered then it is to be under-powered. 94
Old Mar 20, 2008 | 08:59 PM
KingJeff's Avatar
Default Re: (fcm)
Do you guys like that jl setup? I plan on buying the same amp and sub.
Old Mar 21, 2008 | 01:51 AM
mikeycivic's Avatar
Default Re: (KingJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingJeff &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys like that jl setup? I plan on buying the same amp and sub.</TD></TR></TABLE>
I put it in the other day, I bought a sealed qlogic box. I am VERY happy with the bass this sub produces in a coupe. Its loud,and clear. I wired the sub in series like fcm suggested and this things hits hard.
Beckerton
Audio / Security / Video
Jun 21, 2010 06:52 PM
TheTealHatch
12
Sep 4, 2008 02:07 PM
suspendedHatch
10
Mar 25, 2007 08:26 AM
xTurtle714x
Feb 2, 2005 06:20 PM
GSR-REX
11
Jan 24, 2003 07:14 AM
