Timing Issue?
Old Mar 14, 2008 | 11:56 AM
northemt88's Avatar
Default Timing Issue?
I have a d16z6, im have trouble getting the timing right, i have it at tdc, the cam lines up and the crank is dead on tdc, and then i try to adjust ignition timing, i hook up the timing light, im off by 8 degrees after fully retarding the dizzy, if i don't retard the dizzy, or if i advance it, its gets worst, degrees increase, any ideas, am i missing something
Old Mar 14, 2008 | 12:05 PM
Former User's Avatar
Default Re: Timing Issue? (northemt88)
This is obvious, but do you have a jumper wire in the service connector (see below)? Otherwise, double check the cam and crankshaft marks -- they may be off by a tooth.
Old Mar 14, 2008 | 01:05 PM
northemt88's Avatar
Default Re: Timing Issue? (RonJ@HT)
Yeah i do jump it when i time it, also i checked it over and over again there dead on, i even replaced the belt and tensioner, not that i need to but i did
Old Mar 15, 2008 | 12:57 AM
Bond's Avatar
um timing gun have a timing advance dial or option? is it on or set to something? if ur mechanical timing is dead on ur fine; it's not mechanical timing thats off. check ur timing light and jumper wire.
1mistashank
May 29, 2009 08:17 PM
EX-T
Jan 21, 2009 04:16 PM
chengrazng
Aug 23, 2007 11:03 AM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
Magick211
Dec 11, 2001 04:29 PM
