EK Hatch extremely loud and steering wheel vibrates at higher speeds
Old Mar 14, 2008 | 07:47 AM
WPeters's Avatar
Default EK Hatch extremely loud and steering wheel vibrates at higher speeds
it sounds like its coming from the front driver side. The axle has been replaced recently but the sound was there before. Rotors and pads have been replaced so its not a warped rotor.
I have a CEL for my CKF Sensor but i wouldnt think thats anything. Its a swapped motor. Again sound was there before.
The only thing I can think of now is Rims/Tires. My Front Diver Side tire was pretty worn so I rotated my tires. It vibrates and sounds the same. I CLEARLY need new tires and rims but i dont have faith that this would fix the issue.
What else could it be?
Old Mar 14, 2008 | 07:58 AM
yoffer's Avatar
Banned
Sounds like the wheel bearing is going out.
Old Mar 14, 2008 | 08:10 AM
vannak_5415's Avatar
Banned
Default Re: (yoffer)
my car steering shakes at high speeds when i first bought my car, check your wheels if their aligned right, i had to kick out the wheel real hard because the rust on the rims and the studs, i replaced the rims with HX and everything was good now.
Old Mar 14, 2008 | 08:20 AM
Former User's Avatar
Default Re: EK Hatch extremely loud and steering wheel vibrates at higher speeds (WPeters)
Steering wheel vibration at higher speeds generally results from unbalanced wheels.
Old Mar 14, 2008 | 08:27 AM
yoffer's Avatar
Banned
Default Re: EK Hatch extremely loud and steering wheel vibrates at higher speeds (RonJ@HT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT &raquo;</TD></TR><TR><TD CLASS="quote">Steering wheel vibration at higher speeds generally results from unbalanced wheels.</TD></TR></TABLE>
True, this was my first impression, but he said that there was a noise also coming from it. And now thinking after he said that it was a swapped motor im thinking now that he might have the wrong axle
OP: What motor did you swap into your car? What car do you have?
Old Mar 14, 2008 | 08:38 AM
WPeters's Avatar
Default Re: EK Hatch extremely loud and steering wheel vibrates at higher speeds (yoffer)
One Y7 for another Y7
its the correct axles
Old Mar 14, 2008 | 08:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoffer &raquo;</TD></TR><TR><TD CLASS="quote">
Could be two separate problems: Bad wheel bearings and unbalanced wheels.
Old Mar 14, 2008 | 08:43 AM
WPeters's Avatar
Whats involved in swapping the wheel bearing?
I gotta pull the axle remove the rotor and pull it from the knuckle?
markjokeefe
Aug 14, 2008 08:31 PM
lmj2
Oct 8, 2007 10:35 PM
LudeJdm
Jun 12, 2007 05:31 PM
AGENT 99
30
Aug 20, 2004 03:18 AM
Type R
Nov 30, 2001 07:50 PM
