just installed a b16a2 swap in my 98 civic coupe ex question about wirin 3rd plud in ecu
so i just installed a b16a2 in my 98 civic coupe ex now i got a problem i used the stock b16a2 engine harness in the swap with a obd2b ecu so im gonna wire in the "A" plug so i can get my rpm and speedo sensor now the green plug that stayed in the stock cab harness i need a wirin diagram for that plug
here a pic of the green plug
i need a pinout on that green plug that right by the ecu for a stock 98 ek
what are u impling ?? u dont know where the female green plug?? it should be in ur footwell somewhere.. u dont mess with those they just complete ur wiring on ur ej
i install a b16a2 in a 98ek used the b16a2 harness that harness only has 2 plugs that plug into the ecu i need 2 wire in the thrid plug so i can get my speedo tach and other stuff workin all i need is a wire diagram of that green plug from a 98 civic coupe ex
bungdogjb
Dec 8, 2015 05:27 AM
nappyracing001
Aug 16, 2010 05:41 AM
dubzz24
Jan 25, 2008 11:43 AM
h22_crx
Jun 3, 2007 04:50 PM
