Horsepower
Old Mar 13, 2008 | 07:45 PM
theERAisBack's Avatar
Default Horsepower
I have a 1995 Honda Civic Hatch that i have had sittin in my garage for a couple months and i got a motor and am doing a **** ton of work to it, and i have no idea what numbers i am gonna be putting out. Just wanna know what you guys think ill be pushing out.
D16Z6 motor
T3/T4 Turbonetics turbo @ 8 psi
Crower Stg 2 cams
Cam Gears
310 cc Injectors
Skunk2 Intake Manifold
Low compresion Pistons
Eagle Rods
68mm Throttle Body
I think thats about it.
Old Mar 13, 2008 | 07:52 PM
crazyguy's Avatar
Default Re: Horsepower (theERAisBack)
dyno tune is the only way to find out.
Old Mar 13, 2008 | 07:54 PM
97Ej6mike's Avatar
Default Re: Horsepower (crazyguy)
im gonna guess around 347.2whp/240 trq, although my calculations have been known to be incorrect.
Old Mar 13, 2008 | 07:56 PM
T-rexD16's Avatar
i have a friend with a 92 hatch si.with about the same stuff except the cams, and he is on 10psi.he runs mid 13s.I would guess you'll have about 210-230 hp.
Old Mar 13, 2008 | 08:26 PM
duefuss's Avatar
Default Re: Horsepower (T-rexD16)
hey i dont have an estimate but pls do let us know when you get it dyno'd sounds like it will be a perfectly balanced motor though keep us posted
Old Mar 13, 2008 | 08:27 PM
Frickr's Avatar
i would sell that throttle body, thats just an extra 200 that you can put someplace else, when you boost a motor, your forcing air into the motor, 8 psi is 8 psi, doesnt matter what size of hole its going through.stock will do just fine for that. but ever motors different, no way you can really test it out. find a "desktop" dyno, put all the specs in, and it will give you a decent estimate. no way will you be close to knowing till you get it strapped to a dyno
Old Mar 14, 2008 | 07:41 AM
Default Re: Horsepower (Frickr)
Is there anything else that i could bolt on to get more out of it?
Old Mar 15, 2008 | 08:53 AM
duefuss's Avatar
how much of a difference did ou see with you cam? im about to pick up a cam for my ZC
JeffBro
Sep 23, 2012 12:29 AM
TokuiAutowerks
Jul 8, 2009 06:16 AM
playa-ej1
19
Jul 23, 2007 11:08 PM
91crxracer
Mar 27, 2006 01:42 PM
slammed93integra
Mar 4, 2003 02:31 PM
