Need tips RE: Situation!
Old Mar 13, 2008 | 12:59 AM
Mr.Speed's Avatar
Default Need tips RE: Situation!
Ok so I have a starter that I pulled off to get rebuilt and found out there was only on bolt holding it on! Looks like the owner before be broke off a bolt inside.
I got an extractor and drilled the bolt the size the extractor called for but the because the bolt did not brake off even it was very hard to drill the hole! It ended up off center and is close to the edge of the original threaded hole. So the end result I can not get the extractor to grip the bolt it starts to grip the threaded hole the outside and the broke off bolt will not turn out! If I try to use a smaller extractor the drilled hole in the bolt is to big and it will not grip.
So any one have any suggestions any tips?
thanks Darren
Old Mar 13, 2008 | 03:39 AM
Probot's Avatar
Default Re: Need tips RE: Situation! (Mr.Speed)
ask a mechanic or just take the car to a mechanic if you can and see if they can get it out
Old Mar 13, 2008 | 04:07 AM
1qucksol's Avatar
which one broke, the real long one or the shorter one?
Old Mar 13, 2008 | 04:09 AM
blkegcoupe's Avatar
From: ....................................................................................................
not much of a choice to either take it to a mechanic or half *** it with only one
DCRB
13
Mar 23, 2010 09:47 AM
HCivicSi23
Jul 14, 2007 11:15 PM
is3oo
Oct 4, 2003 01:48 PM
Matt B
Apr 20, 2003 07:12 PM
Zulu888
Nov 14, 2001 04:11 PM
