del sol seat rails pictures please
Old Mar 12, 2008 | 06:33 PM
mskansan's Avatar
Default del sol seat rails pictures please
I just bought some del sol seats and the damn rails dont fit into my 1993 del sol. I'm wondering of the rails differed year to year. I tried to put the passenger side in with the supposed "stock" del sol rails and one of the back two holes on the rails are angled like the front mounting holes. The rear seat holes on the car are flat. If someone would post pictures of stock del sol rails, it would be most appreciated. I'm a little pissed that the person I bought the seats from said for sure (twice) they came from a del sol but he had them semi-mounted ( three out of four bolts) in his integra. Conveniently he (Mike@TSR) hasn't returned phone calls today, so I'll try again tomorrow.
Thanks again
Old Mar 13, 2008 | 03:54 AM
mskansan's Avatar
bump
Old Mar 13, 2008 | 04:01 AM
1qucksol's Avatar
i got my seats out right now, 'll try to get some pics up for u
Old Mar 13, 2008 | 09:47 AM
mskansan's Avatar
Default Re: (1qucksol)
thanks i appreciate it. btw still no answer from mike@tsr about the seats
Old Mar 13, 2008 | 01:35 PM
mskansan's Avatar
Default Re: (mskansan)
I guess I can settle down now suppose to get problem fixed some., Once again anybody know if rails differ year to year in del sol series
Old Mar 14, 2008 | 03:47 PM
mskansan's Avatar
bump for pictures please
Old Mar 14, 2008 | 05:40 PM
xunsungheroesx's Avatar
Why are you accusing the guy of lying that the rails were from a Del Sol? The fact that he had only 3 of the 4 bolts in when mounted in his Integra supports that they are probably Del Sol rails.
I purchased Del Sol seats, tried putting them in my Civic and only three of the bolts lined up; one bolt was off slightly. Then I swapped out the Civic rails for the Del Sol rails and to my surprise, only three of the bolts lined up still. I think its just quality variation and slight warping over time of the rails/seat mounts that causes this mismatch. I say that because I loosely bolted in all 4 and then progressively tightened them down and got all 4 to fit no problem even though they didn't seem to line up without the seat bolted down.
Old Mar 14, 2008 | 08:25 PM
mskansan's Avatar
Default Re: (xunsungheroesx)
I accuse him because as far as my knowledge of Honda's goes; I do not believe honda would change a rail pattern on a 5 year production car it would cost money to do so. And besides the fact the rails are about two inches too wide in the front and if it makes sense to you, the rear mounting hole on the outer rail is bent like the front (not modified at all but looks like from the factory bent at an angle like the front) the inner rail rear mounting hole is flat. I own a 1993 honda del sol and the on the inside of the car I need both the rear mounting holes on the rails to be flat and the fronts to be at an angle, this is why I would like pictures to see if this pattern changed from year to year( which I highly doubt) but thanks anyways
Old Mar 14, 2008 | 09:27 PM
blaak-crx's Avatar
Hope this will help No idea what year the seats came from.
Old Mar 14, 2008 | 10:01 PM
DiyCarGuy's Avatar
Default Re: (blaak-crx)
the 96+ del sol seats use a different bracket
i found this out the hard way when i got mine from the junkyard. i had to swap my factory civic brackets onto them they will fit. any bracket off at 92-95 civic or 94-01 integra will work for the del sol
Old Mar 15, 2008 | 06:34 AM
mskansan's Avatar
Default Re: (DiyCarGuy)
i have integra seat out of a 99 or 2000 and they dont line up i need rails like in the pictures above. If you say the rail design has been changed from year to year, then I am at fault for the wrong purchase. I will find out the truth today though. thanks everybody for the info
Old Mar 15, 2008 | 02:44 PM
mskansan's Avatar
well come to find out all production year del sols have one seat rail design and it is the design shown in the pictures above. so i guess does anybody have these for sell?
Old Mar 15, 2008 | 11:20 PM
blaak-crx's Avatar
Those in the picts WERE for sale a few months ago, but now I am selling my Delsol seats with it. Bad timing.
addsmack
Mar 2, 2008 05:04 PM
CooBlueDAB
11
Nov 6, 2004 01:40 PM
12SecHatch
Nov 19, 2002 12:07 AM
IgniteTeg
Sep 9, 2002 11:18 AM
