Turning Off Auto A/C Turn-On
Hello Everyone,
Tried this trick 3 times and still doesn't work. Does anyone else have this problem or is it just me that can't turn 2 ***** to the left, push two buttons in and start the car?
If, once you've done the trick, you rotate the location **** to a defrosting position, the A/C automatically will turn on. There is no way to avoid that. But, you can still turn it off, once it's turned on.
I finally got the trick to work. The only thing different I did from the first and the last is that I had both doors unlocked.
The air recirculation button blinked and then the A/C light turned on. Now I can turn on and off A/C when I want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagneMike33 »</TD></TR><TR><TD CLASS="quote">What is this trick I would like to do this as well?</TD></TR></TABLE>
It's in the FAQ's: https://honda-tech.com/zero...26666
I was trying to remember what I did. I must have tried half a dozen time to make it work.
If I recall, I had all the ***** turned to the left. Then I pressed both buttons and turned the car on. The air recirculation button blinked and then the A/C light turned on.
quick gixxer
Feb 5, 2008 02:04 PM
