96 accord electrical problem
Old Mar 11, 2008 | 09:06 PM
Bigman652's Avatar
Default NEED HELP ASAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
I have a 1996 honda accord and my car is having major issues. about 2 nights ago i was going to get my copy of super smash brothers and it was late at night so i started driving and the whip was messing up so i parked it and rode with my friend. Then when we got back the car started to die as i was on my way home. It stopped a couple of blocks from my house and pushed it with some help there. i check the battery and i replaced it and 3 autoparts stores check my alternater.
Everytime it passed with flying colors so then i put it all back in and it died on me again the next day. So i took out the starter tested and it was fine so what would cause my car to die after i drive it for a little while, if it is not the battery, the alternater, or even the starter?
could it be a wiring harness problem
Old Mar 11, 2008 | 09:13 PM
Bigman652's Avatar
is anyone on so i can fix this problem i need help asap
Old Mar 11, 2008 | 09:40 PM
all-mtr-teg's Avatar
Default Re: (Bigman652)
Stop double posting and post this question in the tech or accord forum, this has nothing to do with all motor forum. But I'll try to help you anyway. Get a voltage meter and check voltage with the car on, see how much the alternator is charging. If its not above 13 volts then your alternator is most likely bad or something else has a short and is drawing alot of power.
Old Mar 11, 2008 | 10:32 PM
Bigman652's Avatar
they said it was good but i replaced it
it might be the fog lights that are in my car
Old Mar 11, 2008 | 10:44 PM
Bigman652's Avatar
i checked could it be the wiring for the alternator?
Old Mar 12, 2008 | 12:33 AM
p10hlm's Avatar
Default Re: NEED HELP ASAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!! (Bigman652)
stop throwing parts at it, if i were you i would look at the eletrical portion of the ignition switch
Old Mar 12, 2008 | 02:34 AM
-RedneckDave-'s Avatar
Working
Wow. I edited your title to help you out a bit.
Old Mar 12, 2008 | 02:13 PM
erk89's Avatar
Default Re: NEED HELP ASAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!! (-RedneckDave-)
you wouldnt happen to have an audio amplifier in ur car would u?
Old Mar 18, 2008 | 09:38 AM
Bigman652's Avatar
Default Re: NEED HELP ASAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!! (erk89)
i figured out the problem
all i did was i redid the wiring going to the alternater and it worked right
htimsda
Honda Accord (2013 - 2015)
Jan 5, 2019 04:42 PM
FreshCD5
Dec 1, 2010 06:41 AM
Jacob Smith
Sep 7, 2010 02:24 AM
DDRnrgONxtc
Sep 20, 2006 09:47 AM
Automag928
Oct 30, 2002 07:49 AM
