JDM D15 question
I have a 92 civic hatch that has the stock d16z6 in it and the motor has developed a bad knock so i was going to replace the motor i called a shop today and the said i should do the jdm d15 swap. they said its comparable to the z6 except for the JDM motor has a hotter cam and higher compression. I was hoping that i could get some info from you guys on here if any of you have used this motor and how well you like it. Any help would be great. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RhDeG6r »</TD></TR><TR><TD CLASS="quote">Buy the D15b. Cheap and easy ifyour on a budget.</TD></TR></TABLE>
and it should have relatively low miles compared to any z6 you will find around. I would swap it in if you are looking to stay with a sohc motor
They're being straight with you. I'm not sure if anyone has determined conclusively that the cam is more aggressive, but there is a slightly higher compression ratio.
BoostdRex
Oct 25, 2006 07:20 PM
kantfadedisazn
Jan 3, 2006 02:33 PM
