Question about shifting
Old Mar 11, 2008 | 04:01 PM
Civic_07's Avatar
Default Question about shifting
I just wanted to know if shifting a little earlier has any effect to the engine?...and what are the pro/cons of shifting earlier/later. And also if it does save gas?
Old Mar 11, 2008 | 04:02 PM
Midori Green's Avatar
Default Re: Question about shifting (Civic_07)
yes shifting early saves gas... the later you shift the more gas you waste because they are higher rpm's and your making the engine work more
Old Mar 11, 2008 | 04:04 PM
BlueIntegraBoy's Avatar
Shifting too early would eat more gas too since you mash the pedal to the floor trying to get up to speed.
Old Mar 11, 2008 | 04:08 PM
Crx_Civic's Avatar
Default Re: Question about shifting (Midori Green)
BUT if u shift so low that ur boggin its bad for gas to because you have to press the accelorator further. IMO gas mileage depends more on throttle position....if you use 1/4 throttle all the way to redline you will get bettter mileage that if u were to shift way low and have the pedal to the floor. corrct me if im wrong?
Civic_07's Avatar
My friend said it would flood the engine?...im guessing flood it with gas?...or like use excessive gas?
Old Mar 11, 2008 | 04:28 PM
Default Re: (Civic_07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_07 &raquo;</TD></TR><TR><TD CLASS="quote">My friend said it would flood the engine?...im guessing flood it with gas?...or like use excessive gas?</TD></TR></TABLE>
your friend is lying you control the gas your car consumes with your right foot
jordan_civic
Oct 4, 2007 01:44 PM
Honda.F1
Honda Civic (2006 - 2015)
Apr 30, 2007 09:06 PM
TeaAddict
Oct 1, 2004 02:53 PM
AznJohn33
Nov 17, 2003 10:43 AM
nY's FiNeSt
26
Oct 3, 2003 05:30 AM
