coolant leak
Old Mar 11, 2008 | 11:01 AM
E JAY 1's Avatar
Default coolant leak(HELP)
i have coolant leaking around the dizzy area. i have a leak to the left of the upper radiator hose next to the dizzy bolts on to the side of the head and one just right under the dizzy. anyone got any ideas or clues of what could be going on? i was thinking either thermostat or bad hose maybe?
Modified by E JAY 1 at 10:38 PM 3/12/2008
Old Mar 11, 2008 | 11:12 AM
E JAY 1's Avatar
Default Re: coolant leak (E JAY 1)
no one know at all?
Old Mar 11, 2008 | 12:23 PM
Former User's Avatar
Might the leak be from around the coolant temperature sensor located below the dizzy?
Old Mar 11, 2008 | 12:27 PM
SFlCrx's Avatar
Default Re: coolant leak (RonJ@HT)
probably leaking from the heater core hose mounted directly under the dist. they tend to leak and burst if you dizzy is leaking oil
Old Mar 11, 2008 | 12:45 PM
HONDACIVC93's Avatar
^^^ +1
Old Mar 11, 2008 | 01:05 PM
E JAY 1's Avatar
Default Re: (HONDACIVC93)
thanks guys..imma check'd out so see what it is..i think the heater core hose might be it..if i dont figure it out ill post pics..if there anymore other than what everyone else said..please list..
Old Mar 11, 2008 | 01:17 PM
SFlCrx's Avatar
Default Re: (E JAY 1)
if its not the heater core hose go to an auto store and see if they have a radiator pressure tester under there tool lending program stuff. snap that bad boy on and see where ur leaking
Old Mar 12, 2008 | 09:30 PM
E JAY 1's Avatar
Default Re: (SFlCrx)
have check on the car yet..havent found the time to..just been sittin in the garage..but just thought of something..the car has lil smoke coming from the engine bay around the dizzy area after driving..i dont know if the car is over heating or is it just the steam coming from coolant hittin hot surface..reason why i dont know if its over heating is because my temp. gauge sits under half way..so i dont know rather is over heating from a blown head gasket, which i hope its not..or is it just a leak from some kind of hose etc.?
Old Mar 12, 2008 | 10:12 PM
E JAY 1's Avatar
no ideas?
Old Mar 13, 2008 | 08:35 AM
E JAY 1's Avatar
could use the help
Old Mar 13, 2008 | 08:40 AM
I wouldn't yet consider a head gasket problem until you have attempted to locate and repair the coolant leak.
Old Mar 14, 2008 | 04:49 PM
E JAY 1's Avatar
Default Re: (RonJ@HT)
got the coolant leak fix..but ran into another problem..i unplug the sensors to get to the heater hose and i dont remeber where one goes..it has a green wire wit yellow stripe..and all the other one plugs up together beside the one i have not pluged..do not remember where it goes.. any ideas..??
prodjay10
Honda Civic (2001 - 2005)
May 27, 2015 09:23 AM
LGxGirL
Nov 26, 2012 10:58 AM
SpazMan
Jun 12, 2008 10:22 AM
tigueremalo
Jul 10, 2006 07:16 PM
Jeffrey9
Nov 16, 2005 10:31 AM
