coolant leak
coolant leak(HELP)
i have coolant leaking around the dizzy area. i have a leak to the left of the upper radiator hose next to the dizzy bolts on to the side of the head and one just right under the dizzy. anyone got any ideas or clues of what could be going on? i was thinking either thermostat or bad hose maybe?
Modified by E JAY 1 at 10:38 PM 3/12/2008
Re: coolant leak (RonJ@HT)
probably leaking from the heater core hose mounted directly under the dist. they tend to leak and burst if you dizzy is leaking oil
Re: (HONDACIVC93)
thanks guys..imma check'd out so see what it is..i think the heater core hose might be it..if i dont figure it out ill post pics..if there anymore other than what everyone else said..please list..
Re: (E JAY 1)
if its not the heater core hose go to an auto store and see if they have a radiator pressure tester under there tool lending program stuff. snap that bad boy on and see where ur leaking
Re: (SFlCrx)
have check on the car yet..havent found the time to..just been sittin in the garage..but just thought of something..the car has lil smoke coming from the engine bay around the dizzy area after driving..i dont know if the car is over heating or is it just the steam coming from coolant hittin hot surface..reason why i dont know if its over heating is because my temp. gauge sits under half way..so i dont know rather is over heating from a blown head gasket, which i hope its not..or is it just a leak from some kind of hose etc.?
Re: (RonJ@HT)
got the coolant leak fix..but ran into another problem..i unplug the sensors to get to the heater hose and i dont remeber where one goes..it has a green wire wit yellow stripe..and all the other one plugs up together beside the one i have not pluged..do not remember where it goes.. any ideas..??
