front strut bar question!!! for 1996-2000 ek owners!!!
Old Mar 11, 2008 | 10:24 AM
vietshinobi's Avatar
Default front strut bar question!!! for 1996-2000 ek owners!!!
i wanted to put a gsr front top strut bar in my ek but they dont have the nut for it like the gsr...did you guys drill holes for them do did you guys just buy a different kind of strut?
Old Mar 11, 2008 | 10:29 AM
Eran's Avatar
HT White Ops
I drilled holes in the pre-stamped dimples and used grade 10 metric stainless hardware.
Old Mar 11, 2008 | 10:31 AM
-Gambit-'s Avatar
Default Re: front strut bar question!!! for 1996-2000 ek owners!!! (vietshinobi)
if you want to run a oem bar like the gsr, si or ctr. You have to drill the holes for them. And if you dont want to drill holes you could always buy a bar for you car, such as the spoon, skunk2, neuspeed, carbing, passwordjdm.com and so on...
Old Mar 11, 2008 | 11:14 AM
Malakai's Avatar
are the holes threaded already or is this something that has to be done as well?
Old Mar 11, 2008 | 11:16 AM
Eran's Avatar
HT White Ops
Default Re: (Malakai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai &raquo;</TD></TR><TR><TD CLASS="quote">are the holes threaded already or is this something that has to be done as well?</TD></TR></TABLE>
Nope, no threads. Best bet is to tack a bolt up from inside the fender well.
Old Mar 11, 2008 | 11:19 AM
Malakai's Avatar
ok cool. thats what i was thinking.
Old Mar 11, 2008 | 03:16 PM
did you tap the holes or just drill it?
Old Mar 11, 2008 | 03:21 PM
Malakai's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietshinobi &raquo;</TD></TR><TR><TD CLASS="quote">did you tap the holes or just drill it?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">I drilled holes in the pre-stamped dimples and used grade 10 metric stainless hardware.</TD></TR></TABLE>
Best bet is to tack a bolt up from inside the fender well.</TD></TR></TABLE>
wow you suck at reading
Old Mar 11, 2008 | 04:07 PM
BlueIntegraBoy's Avatar
Drill four holes. Insert bolts from fender up. Nut it at the top. Make sure you get washers.
Old Mar 11, 2008 | 09:34 PM
wow you suck at reading </TD></TR></TABLE>
is there any other ways it was done? dont really want to do it that way
Old Mar 11, 2008 | 10:32 PM
x0!'s Avatar
x0!
weld it on? lols how else you gonna do it?
Old Mar 11, 2008 | 10:39 PM
99GreenEX's Avatar
* B A N N E D *
They make grade 10 metric hardware? I work as a heavy equipment mechanic, and as far as i know grade 8 is the strongest...
Old Mar 11, 2008 | 10:46 PM
Eran's Avatar
HT White Ops
Default Re: (99GreenEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99GreenEX &raquo;</TD></TR><TR><TD CLASS="quote">They make grade 10 metric hardware? I work as a heavy equipment mechanic, and as far as i know grade 8 is the strongest...</TD></TR></TABLE>
I was under the impression that Grade 10 metric was equal to Grade 8 SAE (highest grade).
Old Mar 12, 2008 | 11:19 AM
99GreenEX's Avatar
* B A N N E D *
SAE is metric... far as i know. I've never heard of grade 10 bolts, and most CAT equipment use metric bolts...
Old Mar 12, 2008 | 11:25 AM
Malakai's Avatar
I think the OEM lca bolts are grade 10 IIRC. Most highest grade from stores however is a grade 8.8 i think.
Old Mar 12, 2008 | 11:33 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99GreenEX &raquo;</TD></TR><TR><TD CLASS="quote">SAE is metric... far as i know. I've never heard of grade 10 bolts, and most CAT equipment use metric bolts...</TD></TR></TABLE>
Are you retarded?
SAE is the Society of Automotive Engineers. They lend their measurement practice to things such as motor oil and tool sizing.
SAE sockets are ones such as 3/8", 1/2" 1/4" etc.
Metric sockets are ones such as 8mm, 10mm, 12mm, etc.
Old Mar 12, 2008 | 12:31 PM
Malakai's Avatar
Lol bud you really need to go back to school! Or should Eran take you there
808k20hatch
Sep 8, 2007 07:42 AM
dj_audio
Nov 27, 2005 08:31 PM
CRX_Type_R
20
Nov 20, 2004 12:49 PM
JDM R
15
May 12, 2004 03:36 PM
Hoppa
Jan 13, 2004 06:12 AM
