what distributor will work? please help!!
Old Jul 7, 2002 | 09:56 PM
kingrobby's Avatar
Default what distributor will work? please help!!
what distributor will work with a 2000 si head? I am getting the engine minus the dist. i am going to use the pistons and the head to do a ls\vtec but i need a dist. does anybody have one? how much? are other vtec dist. compatible, does obd1 and 2 matter. thank you
Old Jul 7, 2002 | 11:18 PM
4drlsvtec's Avatar
Default Re: what distributor will work? please help!! (kingrobby)
What kind of car do you have!!!
Doug, 4drlsvtec
Old Jul 8, 2002 | 04:38 AM
No-Gi's Avatar
Default Re: what distributor will work? please help!! (4drlsvtec)
I have an OBD-II distributor FS if you need it. PM me
Old Jul 8, 2002 | 06:57 AM
Jared's Avatar
any b series dohc vtec dist will bolt to the head. if you have a 92-95 car, get an obd1, if you have a 96+ car, get an obd2 dist.
Old Jul 8, 2002 | 08:58 PM
kingrobby's Avatar
Sorry, i totally forgot to say that i have a 94 integra ls. the head is from a 2000 si. What exactly is the difference between my dist. and the dohc vtec dist. do you know which ecu would be the best also?
Old Jul 9, 2002 | 12:42 AM
Katman's Avatar
The mounting legs on an LS distributor vs. a DOHC VTEC distributor is where they differ from each other. Its suggested that you use an OBD1 or 92-95 DOHC VTEC distributor with your engine setup since your 94 integra is OBD1 equipped.
It's also suggested to run an OBD1 VTEC ecu and possibly have it reprogrammed depending on your application.
If you somehow wind up with the 00 Si ignition, try and locate a 96-01 OBD2 integra GSR or ITR engine harness. It will plug and play into your 94/OBD1 equipped integra.
[Modified by Katman, 1:43 AM 7/9/2002]
Old Jul 12, 2002 | 05:22 AM
Red_Si's Avatar
ive got ecus what you need?
ProricanEF
Mar 27, 2008 09:08 AM
Iwant2run13s
Sep 21, 2007 06:07 PM
delux247
Apr 4, 2003 05:57 PM
RAWB
Mar 20, 2003 01:35 PM
Bnjmn
Mar 1, 2002 04:03 PM
