first ever header!!
Old Mar 10, 2008 | 06:19 PM
vtec_lude's Avatar
Default first ever header!!
Hi guys,
Had some spare 180 degree bends laying around so I thought I'd try and make a header for my prelude.
Started by making a Y pipe
Made a jig and cut and tacked 1 runner first
Stated piecing it together. Held on by tape at this stage. Speeds things up a lot!
Tacked
next to the ebay one
checking fitment
welded some of it up
Got my gas lense and it made a big difference!
I actually finished welding up all the runners tonight but haven't taken anymore pics. Been welding for 3.5 months now so still much to improve!
Thanks for looking!
Old Mar 11, 2008 | 10:31 AM
12sec14's Avatar
Default Re: first ever header!! (vtec_lude)
Nice!
I have all the gear but no Idea!
I would love to be able to do this..
How did you work out what size primarys you needed?
Paul.
Old Mar 11, 2008 | 12:11 PM
RC000E's Avatar
Default Re: first ever header!! (12sec14)
Not bad for the first effort....came out alright. I do see cheater cuts though, which cost you big in terms of flow. The collector convergence looks steep as well. Overall not bad though.
Old Mar 11, 2008 | 12:18 PM
.dave's Avatar
i HAS questions ?
Default Re: first ever header!! (RC000E)
Looks damn good for your first header ever and not a lot of welding experience.
Did you do anything in terms of runner length/diameter calculation?
Old Mar 11, 2008 | 01:27 PM
vtec_lude's Avatar
The runners are approximately 18 inches long each. I tried to get the runners as close to equal length as I could, still needs a bit of work.
the cuts on runner #4 is actually 1 45 debree bend that I cut up a couple of times and it didn't fit anywhere. Once I lined it all up it seemed to fit there so I thought I'd welded it back up on that runner.
I'm actually hoping it'll slow the gas flow a little as that runner is ever so slightly longer than the others.
Still new to TIG welding. Still got to work out creative ways of welding in tight spaces, but the gas lense does give me that flexibility.
thanks for all the comments!
Old Mar 11, 2008 | 01:29 PM
vtec_lude's Avatar
Also RC000E, should I make the collectors not at such an angle? Any help is much appreciated.
Thanks
Old Mar 11, 2008 | 10:42 PM
quicksilver1689's Avatar
i ♥ snails
i always thought the steeper angles were better or is that just for turbo mani collectors?
Old Mar 12, 2008 | 08:41 AM
RaceCarRyne's Avatar
Default Re: (quicksilver1689)
the angle the tube comes out of the head is very cirtical also. did you measure that? how big are the primarys? what what size secondarys are you going to use?
Old Mar 12, 2008 | 11:18 AM
vtec_lude's Avatar
#1,#2 and #3 are 90 degrees. #4 is a 45 degree bend. From the runner #1,#2 and #3 run down to 45 degree bends and #4 runs down to a 90 degree bend.
The primaries are 1.75" and the secondaries will be 2 inch going into a 2.5inch collector.
Old Mar 12, 2008 | 12:33 PM
Default Re: (vtec_lude)
not the bends, the angle it leaves the head.
Old Mar 14, 2008 | 05:24 AM
vtec_lude's Avatar
Well the manifold is all welded up. Just need to work on the downpipe.
Here are the pics
Old Mar 14, 2008 | 01:33 PM
PolishSasquatch's Avatar
looks good dude, if it was me personalyl i would have chamfered the edges where it is to be welded up
Old Mar 14, 2008 | 02:04 PM
vtec_lude's Avatar
bevel?
Does it really need to be beveled? it's only 1.5mm thick tubing.
Old Mar 14, 2008 | 05:15 PM
KENetics1's Avatar
Default Re: (PolishSasquatch)
i'm guessing it's probably 16g so there's really no need to bevel the pipes.
Old Mar 15, 2008 | 10:56 AM
hybrid2007's Avatar
Default Re: (KENetics1)
Theres no need to although i find it easier to get a neat bead if you have a groove to dip the filler into.
Did you backpurge?
Old Mar 15, 2008 | 11:29 AM
dohcnotec1's Avatar
Default Re: (hybrid2007)
awesome! i would be interested in a dyno just see what you made
Old Mar 15, 2008 | 01:14 PM
KENetics1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2007 &raquo;</TD></TR><TR><TD CLASS="quote">Theres no need to although i find it easier to get a neat bead if you have a groove to dip the filler into.
good point
onepoint6i
Nov 9, 2008 10:33 AM
onefstek
Welding / Fabrication
11
Dec 13, 2006 06:51 AM
itrdriver1071
Dec 9, 2005 08:07 PM
MysteryWagon
59
Mar 16, 2005 02:10 PM
speedymon
Jan 5, 2004 09:10 PM
