LS VTEC ISSUES!!!!!!!!!!!!
Old Mar 10, 2008 | 11:33 AM
stevew84's Avatar
Banned
Default LS VTEC ISSUES!!!!!!!!!!!!
alright the deal is i have a 97 civic hb with b18c head, b20b block. (gsr hear, crv block) known as the crvtec or lsvtec take your pick. anyways when i bought the car, the throttle cable was NOT sitting on a mount but instead zip tied to a fuel line. The cable is from an acura LS for some reason and is too long. I cannot adjust the tension for 2 reasons, it is too long and there is no mounting bracket. the spindle where the cable is winded up is there on the throttle body. Ive called honda and acura dealers and honda specific shops but no one can help me.
some of the cables i have heard to use are...
99-00 civic si
97 civic hb
integ grs
94 del sol b16 vtec
as the list shows, people have a wide range of opinions. i also need the mounting bracket so that poses even more problems...if anyone can help me i would greatly appreciate some feed back.
thanks,
steve
Old Mar 10, 2008 | 11:39 AM
crazyguy's Avatar
Default Re: LS VTEC ISSUES!!!!!!!!!!!! (stevew84)
u can only use gsr throttle cable with gsr throttle cable bracket p72.. 99-00 civic si and 94 del sol b16 vtec and integra LS share the same throttle cable with is too long for your b18c1 head
Old Mar 10, 2008 | 11:54 AM
stevew84's Avatar
Banned
Default Re: LS VTEC ISSUES!!!!!!!!!!!! (crazyguy)
ok so the bracket needs to be for the p72 ecu? when i saw that number thats the first thing i thought of was the ecu....if im mistaken let me know. i will include pictures tonite when im out of work. thanks for the help tho i will post before and after pix
Old Mar 10, 2008 | 11:56 AM
BryanM.'s Avatar
Resident Gearhead
No I think crazyguy was talking about the p72 intake manifold. Correct?
stevew84's Avatar
Banned
also my idle is at like 200rpm, it dies if i start it up in neutral and let off gas. i gotta keep it reved at about 1500 for like 30 seconds then slowly ease off....
Old Mar 10, 2008 | 11:57 AM
stevew84's Avatar
Banned
the mani that is on the head is the stock b18c1 mani.
crazyguy's Avatar
p72 is the oem part numbers for gsr..not only meant for ecu
Old Mar 10, 2008 | 11:58 AM
crazyguy's Avatar
Default Re: LS VTEC ISSUES!!!!!!!!!!!! (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">No I think crazyguy was talking about the p72 intake manifold. Correct?</TD></TR></TABLE>
yeah i was actually meant p72 throttle cable bracket. cause there is going to be a "P72" stampped on that bracket
Old Mar 10, 2008 | 11:59 AM
crazyguy's Avatar
Default Re: (stevew84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevew84 &raquo;</TD></TR><TR><TD CLASS="quote">the mani that is on the head is the stock b18c1 mani.</TD></TR></TABLE>
b18c1 intake manifold is also known as p72 intake manifold and agian, there should be "P72" stampped at the back of the intake manifold
for example. the pic shown below is my ITR intake manifold and it stampped "P73"
Old Mar 10, 2008 | 12:06 PM
stevew84's Avatar
Banned
thanks man ill post pix later tonite...any idea on the low idle? im thinking its cuz too much slack on the cable?
Old Mar 10, 2008 | 12:08 PM
stevew84's Avatar
Banned
and even tho its an EK the gsr cable will fit length wise?
Old Mar 10, 2008 | 12:10 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevew84 &raquo;</TD></TR><TR><TD CLASS="quote">and even tho its an EK the gsr cable will fit length wise?</TD></TR></TABLE>
yeah .
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevew84 &raquo;</TD></TR><TR><TD CLASS="quote">thanks man ill post pix later tonite...any idea on the low idle? im thinking its cuz too much slack on the cable?</TD></TR></TABLE>
No, cable won't effect idle if it has slack. I would start but cleaning the IACV.
delsoldrew
May 5, 2009 09:04 AM
stevew84
Mar 11, 2008 09:36 AM
stevew84
Mar 10, 2008 12:08 PM
tr123gone
Jan 2, 2008 06:15 PM
