How to change tranny fluid?
Old Mar 10, 2008 | 07:12 AM
Tuesdaynightfever's Avatar
Default How to change tranny fluid?
I remember seeing a very good DIY on here, and I was just wondering if anyone can post the link? I tried searching but didn't have luck with any threads with pictures, like the one I am referring to.
Thanks in advance.
Old Mar 10, 2008 | 07:13 AM
IIXtremeHansen's Avatar
Default Re: How to change tranny fluid? (Tuesdaynightfever)
Use a ratchet to unbolt it and put it through your VSS(Vehicle speed sensor) 2-3 Quarts Syncromesh.
http://www.c-speedracing.com/h...d.php
There you go
Old Mar 10, 2008 | 07:25 AM
Default Re: How to change tranny fluid? (Dickies_n_FlipFlops)
Thanks man. Couldn't I just fill it through the fill hole on the tranny?
Old Mar 10, 2008 | 07:29 AM
Anyone know offhand what size the fill and drain plugs are for a 00 civic, d16y7 tranny.
Thanks
Old Mar 10, 2008 | 07:31 AM
ProMotive's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuesdaynightfever &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know offhand what size the fill and drain plugs are for a 00 civic, d16y7 tranny.
Thanks </TD></TR></TABLE>
The fill plug on my both of my B series are 17mm I believe, it may or may not be the same on a D series
Old Mar 10, 2008 | 07:38 AM
Default Re: How to change tranny fluid? (ProMotiveConcepts)
I also believe it is a 17mm, can anyone confirm this? Anyone know the drain plug size?
Old Mar 10, 2008 | 07:50 AM
BryanM.'s Avatar
Resident Gearhead
Drain plug has a square hole (for lack of a better term), insert a 3/8" drive rachet to remove it.
Fill plug is 17mm for both D and B-series.
Old Mar 10, 2008 | 07:53 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: How to change tranny fluid? (mcvtec)
This write up is about replacing axles, but it also shows how to replace trans fluid:
https://honda-tech.com/zerothread?id=382416
Old Mar 10, 2008 | 07:59 AM
Perfect. Just what I wanted to hear.
Is it possible to do this without taking off the tire? Only reason I am asking is because I am at school, and will be doing this on the street. I believe my jackstands are at home..
Old Mar 10, 2008 | 08:00 AM
BryanM.'s Avatar
Resident Gearhead
Yes, no need to remove wheel, last time I did it I didn't even use jackstands.
Old Mar 10, 2008 | 08:05 AM
Very good to hear. So I can do this using just a jack, 3/8 drive wrench, and a 17mm socket?
Now, next question. Is it possible to do this without jacking up the car? My car is stock height.
Old Mar 10, 2008 | 08:09 AM
BryanM.'s Avatar
Resident Gearhead
Yes, you can do this with all 4 wheels touching the ground, as long as you have a container (to catch the old oil) short enough to fit under your car.
On a side note, I normally use a length of clear tubing and a funnel to refill the tranny, keep adding oil 'til it spills out the fill hole (fool proof).
Old Mar 10, 2008 | 08:12 AM
Thanks for all the help. I will be buying a funnel and tubing this week. How big is the fill hole, just to make sure the tubing I get isn't too big.
Old Mar 10, 2008 | 08:15 AM
BryanM.'s Avatar
Resident Gearhead
1/2" inside diameter will work.
Old Mar 10, 2008 | 08:19 AM
Good deal. Thanks again.
Old Mar 10, 2008 | 08:21 AM
BryanM.'s Avatar
Resident Gearhead
No problem
Old Mar 10, 2008 | 08:24 AM
One more question, is the drain/fill plug on the driver or passenger side?
Old Mar 10, 2008 | 08:34 AM
ek4_b16a's Avatar
both are located on the passenger side of the tranny...the only side that you can get to no probs...gl
Old Mar 10, 2008 | 08:41 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: How to change tranny fluid? (ek4_b16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4_b16a &raquo;</TD></TR><TR><TD CLASS="quote">both are located on the passenger side of the tranny...the only side that you can get to no probs...gl</TD></TR></TABLE>
Correct
<FONT COLOR="red">It's a bit tight but can be done this way</FONT>
Old Mar 10, 2008 | 08:44 AM
.Radical_Edward.'s Avatar
Bounty - € 8,000,000
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">This write up is about replacing axles, but it also shows how to replace trans fluid:
This is the transmission fluid changing thread in the FAQ at the top of this forum.
https://honda-tech.com/zerothread?id=851521
In that FAQ Thread you can find out many things. Please use it next time. It's pretty much the same for D/B
Thanks again guys
Old Mar 10, 2008 | 08:48 AM
GM Syncromesh is also a great choice for replacement.
http://www.superhonda.com/foru...88051/
If you are in a bind, Honda MTF is the same as 10w30.
Old Mar 10, 2008 | 08:49 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: How to change tranny fluid? (.Radical_Edward.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Radical_Edward. &raquo;</TD></TR><TR><TD CLASS="quote">
In that FAQ Thread you can find out many things. Please use it next time. It's pretty much the same for D/B</TD></TR></TABLE>
I dare you to
Old Mar 10, 2008 | 09:03 AM
I dare you to </TD></TR></TABLE>
I don't even have to.
aser1z
Sep 7, 2005 08:17 PM
litterbox
Feb 14, 2005 12:19 PM
Bigwool
Dec 17, 2004 07:56 PM
CaTiRo
15
Aug 31, 2004 03:18 AM
dork
Jul 9, 2004 09:27 AM
