How to change tranny fluid?
I remember seeing a very good DIY on here, and I was just wondering if anyone can post the link? I tried searching but didn't have luck with any threads with pictures, like the one I am referring to.
Thanks in advance. |
Re: How to change tranny fluid? (Tuesdaynightfever)
Use a ratchet to unbolt it and put it through your VSS(Vehicle speed sensor) 2-3 Quarts Syncromesh.
http://www.c-speedracing.com/h...d.php There you go https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: How to change tranny fluid? (Dickies_n_FlipFlops)
Thanks man. Couldn't I just fill it through the fill hole on the tranny?
Anyone know offhand what size the fill and drain plugs are for a 00 civic, d16y7 tranny.
Thanks https://honda-tech.com/forums/images/smilies/embeer.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuesdaynightfever »</TD></TR><TR><TD CLASS="quote">Anyone know offhand what size the fill and drain plugs are for a 00 civic, d16y7 tranny.
Thanks https://honda-tech.com/forums/images/smilies/embeer.gif </TD></TR></TABLE> The fill plug on my both of my B series are 17mm I believe, it may or may not be the same on a D series https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: How to change tranny fluid? (ProMotiveConcepts)
I also believe it is a 17mm, can anyone confirm this? Anyone know the drain plug size?
Drain plug has a square hole (for lack of a better term), insert a 3/8" drive rachet to remove it.
Fill plug is 17mm for both D and B-series. |
Re: How to change tranny fluid? (mcvtec)
This write up is about replacing axles, but it also shows how to replace trans fluid:
https://honda-tech.com/zerothread?id=382416 |
Perfect. Just what I wanted to hear.
Is it possible to do this without taking off the tire? Only reason I am asking is because I am at school, and will be doing this on the street. I believe my jackstands are at home.. |
Yes, no need to remove wheel, last time I did it I didn't even use jackstands.
Very good to hear. So I can do this using just a jack, 3/8 drive wrench, and a 17mm socket?
Now, next question. Is it possible to do this without jacking up the car? My car is stock height. |
Yes, you can do this with all 4 wheels touching the ground, as long as you have a container (to catch the old oil) short enough to fit under your car.
On a side note, I normally use a length of clear tubing and a funnel to refill the tranny, keep adding oil 'til it spills out the fill hole (fool proof). |
Thanks for all the help. I will be buying a funnel and tubing this week. How big is the fill hole, just to make sure the tubing I get isn't too big.
1/2" inside diameter will work.
Good deal. Thanks again. https://honda-tech.com/forums/images...s/emcocktl.gif
One more question, is the drain/fill plug on the driver or passenger side?
both are located on the passenger side of the tranny...the only side that you can get to no probs...gl
Re: How to change tranny fluid? (ek4_b16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4_b16a »</TD></TR><TR><TD CLASS="quote">both are located on the passenger side of the tranny...the only side that you can get to no probs...gl</TD></TR></TABLE>
Correct https://honda-tech.com/forums/images/smilies/emthup.gif <FONT COLOR="red">It's a bit tight but can be done this way</FONT> https://i261.photobucket.com/albums/...0310081230.jpg |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">This write up is about replacing axles, but it also shows how to replace trans fluid:
https://honda-tech.com/zerothread?id=382416 </TD></TR></TABLE> This is the transmission fluid changing thread in the FAQ at the top of this forum. https://honda-tech.com/zerothread?id=851521 In that FAQ Thread you can find out many things. Please use it next time. https://honda-tech.com/forums/images/smilies/emwink.gif It's pretty much the same for D/B |
Thanks again guys https://honda-tech.com/forums/images/smilies/emthup.gif
GM Syncromesh is also a great choice for replacement.
http://www.superhonda.com/foru...88051/ If you are in a bind, Honda MTF is the same as 10w30. |
Re: How to change tranny fluid? (.Radical_Edward.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Radical_Edward. »</TD></TR><TR><TD CLASS="quote">
This is the transmission fluid changing thread in the FAQ at the top of this forum. https://honda-tech.com/zerothread?id=851521 In that FAQ Thread you can find out many things. Please use it next time. https://honda-tech.com/forums/images/smilies/emwink.gif It's pretty much the same for D/B</TD></TR></TABLE> I dare you to http://images.honda-tech.com/new/1/report.gif https://honda-tech.com/forums/images...s/emsmilep.gif |
I dare you to http://images.honda-tech.com/new/1/report.gif https://honda-tech.com/forums/images...s/emsmilep.gif </TD></TR></TABLE> I don't even have to. https://honda-tech.com/forums/images...s/emsmilep.gif |
