How to change tranny fluid?
I remember seeing a very good DIY on here, and I was just wondering if anyone can post the link? I tried searching but didn't have luck with any threads with pictures, like the one I am referring to.
Thanks in advance.
Thanks in advance.
Re: How to change tranny fluid? (Tuesdaynightfever)
Use a ratchet to unbolt it and put it through your VSS(Vehicle speed sensor) 2-3 Quarts Syncromesh.
http://www.c-speedracing.com/h...d.php
There you go
There you go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuesdaynightfever »</TD></TR><TR><TD CLASS="quote">Anyone know offhand what size the fill and drain plugs are for a 00 civic, d16y7 tranny.
Thanks </TD></TR></TABLE>
The fill plug on my both of my B series are 17mm I believe, it may or may not be the same on a D series
Resident Gearhead
Re: How to change tranny fluid? (mcvtec)
This write up is about replacing axles, but it also shows how to replace trans fluid:
https://honda-tech.com/zerothread?id=382416
Perfect. Just what I wanted to hear.
Is it possible to do this without taking off the tire? Only reason I am asking is because I am at school, and will be doing this on the street. I believe my jackstands are at home..
Very good to hear. So I can do this using just a jack, 3/8 drive wrench, and a 17mm socket?
Now, next question. Is it possible to do this without jacking up the car? My car is stock height.
Resident Gearhead
Yes, you can do this with all 4 wheels touching the ground, as long as you have a container (to catch the old oil) short enough to fit under your car.
On a side note, I normally use a length of clear tubing and a funnel to refill the tranny, keep adding oil 'til it spills out the fill hole (fool proof).
Thanks for all the help. I will be buying a funnel and tubing this week. How big is the fill hole, just to make sure the tubing I get isn't too big.
both are located on the passenger side of the tranny...the only side that you can get to no probs...gl
Resident Gearhead
Re: How to change tranny fluid? (ek4_b16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4_b16a »</TD></TR><TR><TD CLASS="quote">both are located on the passenger side of the tranny...the only side that you can get to no probs...gl</TD></TR></TABLE>
Correct
<FONT COLOR="red">It's a bit tight but can be done this way</FONT>
Correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">This write up is about replacing axles, but it also shows how to replace trans fluid:
This is the transmission fluid changing thread in the FAQ at the top of this forum.
https://honda-tech.com/zerothread?id=851521
In that FAQ Thread you can find out many things. Please use it next time. It's pretty much the same for D/B
GM Syncromesh is also a great choice for replacement.
http://www.superhonda.com/foru...88051/
If you are in a bind, Honda MTF is the same as 10w30.
Resident Gearhead
Re: How to change tranny fluid? (.Radical_Edward.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Radical_Edward. »</TD></TR><TR><TD CLASS="quote">
In that FAQ Thread you can find out many things. Please use it next time. It's pretty much the same for D/B</TD></TR></TABLE>
I dare you to
I dare you to
I dare you to </TD></TR></TABLE>
I don't even have to.
aser1z
09-07-2005 08:17 PM
litterbox
02-14-2005 12:19 PM
