odb2 ecu on a odb 1 car ? ?
will it work ?
will the distributer and other stuff from a odb1 work on a odb2 ecu??
I have a 93 civic and i just swapped in a d16z6 , the guy i bought it from said it has a ecu from a 2000 (odb-2) (the car also had a d18y8 but i blew that motor)
also the check engine light bulb is removed from the dash, i never cared about it till now cause im having some serious issues with the car (wont idle right and bogs badly )
If I put the bulb back in , will I even be able to check for codes since the ecu is a odb 2?
could my probem be the odb2 ecu ??
Modified by maxspeed96ct at 7:55 PM 3/9/2008
Well, you should definitely put back the bulb for your CEL and see if its throwing codes if your car isn't running correctly.
So are you running the obd2 ECU right now? Because you sound like your asking if it will work, but your saying that your problem could be the obd2 ECU your running now?
I don't think the distributor should matter if you have an obd1 to obd2 conversion harness for your ECU.
Well im just runing out of ideas on what can be wrong .
I swapped out the entie intake manifold and allthe sensors from my blow y8 motor cause i know everything on there was good. Im realy running out of ideas.
Im just asking also if i put the cel bulb back in ,, will i even e able to check for codes since its odbs
the p28 ecu is OBD1........ not OBD2, so you have the right ecu.....you can rule that out!!! Put the bulb back in the cluster and flash your codes.....then we can help you further....
K guys bulb is back in , I also found the jumper(the previous owner cut off the blue clip and jet left the to wires hanging. I was orried at first.
My only codes are
19 Automatic transmission lockup control valve
Im 5spd but im assuming my ecu is from a auto
and 22 VTEC pressure valve
Could the vtech pressure valve be whats causeing my crazy ible and serious lag/ bogging?
From what i first thought it was is the feul pump, at least thats what it feels like....
My only codes are
bk7794
May 29, 2012 09:32 AM
drumminforev
19
Oct 6, 2006 12:12 AM
impact_blu
Aug 18, 2005 01:36 PM
TurboRedSi
Jul 17, 2003 10:59 PM
