why would idle go up when A/C is cut on?
when I turn on my A/C my RPMs go up by 600 and start hopping. what would cause this? It only hops with the A/C on and stops when i turn it off. also when i turn my lights on it whines if i cut them off it stops.
it almost sounds like you have a bad ground. i had a problem like that when i turn my lights on my windsield wipers came on. i would check that first. but i am not an expert hopefully i helped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allshownogo »</TD></TR><TR><TD CLASS="quote">where do i look for a ground and also the seprate issue why would rpms go crazy with a/c on</TD></TR></TABLE>
A/C is belt driven, it puts more load on the engine, the engine compensates.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allshownogo »</TD></TR><TR><TD CLASS="quote">when I turn on my A/C my RPMs go up by 600 and start hopping. what would cause this? It only hops with the A/C on and stops when i turn it off. also when i turn my lights on it whines if i cut them off it stops.
It's normal for the ECU to increase engine rpm with increased load, for example when the A/C is ON. The hopping rpm and whining, however, is abnormal. Check whether the alternator belt is loose and slipping. If the belt is fine, the alternator might be bad.
</TD></TR></TABLE>It's normal for the ECU to increase engine rpm with increased load, for example when the A/C is ON. The hopping rpm and whining, however, is abnormal. Check whether the alternator belt is loose and slipping. If the belt is fine, the alternator might be bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat »</TD></TR><TR><TD CLASS="quote">
A/C is belt driven, it puts more load on the engine, the engine compensates.</TD></TR></TABLE>
It can be worse if you have underdrive pullies.
no underdrive pulleys its a stock d15b7 i just need it to last until i cant buy my swap but anyway a bad alternator could cause a bad idle with the a/c on? ive already cleaned IACV,FITV, just put on a used T/B with TPS and MAP sensors. newT/B gasket. i fixed previous powerloss prob but now this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allshownogo »</TD></TR><TR><TD CLASS="quote">...but anyway a bad alternator could cause a bad idle with the a/c on? </TD></TR></TABLE>
Yes. Take your car to AutoZone where they will test your battery and alternator free of charge. But first check whether the belt is loose, glazed, or slipping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allshownogo »</TD></TR><TR><TD CLASS="quote">would that also affect my idle being high for a few seconds when i come to a stop(alternator)</TD></TR></TABLE>
Possibly. Increased electrical load (e.g., A/C or headlights) will increase engine rpm, which could fluctuate up and down if the alternator intermittently failed to supply adequate charge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allshownogo »</TD></TR><TR><TD CLASS="quote">well if i have nothing on and im coming to a stop my car will stay at 100RPMs for about 4 seconds before droping down to normal. this is with nothing on not even radio</TD></TR></TABLE>
This problem probably has a separate cause from the potential alternator problem mentioned earlier.
psyonicdeath
10
Jul 28, 2005 10:07 PM
I8ayellowcrayon
Nov 7, 2004 07:18 PM
