What does this mean?
Old Mar 9, 2008 | 04:43 PM
NuRon's Avatar
Default What does this mean?
Little chip of the side there, my whole brakes are wonky with its chattering (after taking the anti-chatter clips off, otherwise they rubbed on the outer surface of the rotor but people said theirs doesn't chatter even with them removed) and random squeaking (possibly from cheap pads).
Old Mar 9, 2008 | 04:52 PM
NJIN BUILDR's Avatar
Default Re: What does this mean? (NuRon)
Wrong rotor caliper combination maybe.Deeply rusted rotors will do this even after being resurfaced too.Putting new pads on old unsurfaced rotors will look like that.
Old Mar 9, 2008 | 05:16 PM
NuRon's Avatar
Thank you for the quick reply. I tried to take my rotors in for resurfacing but they said that it didn't need it. I guess buying new replacement rotors and pads to start all over is the way to go?
BTW, do you know what it means when the anti-chatter (V-shaped) clips rub on the outer edge of the rotors? That's why I replaced my pads in the first place because I didn't notice it.
Old Mar 9, 2008 | 05:25 PM
Default Re: (NuRon)
Those are pad wear indicators.They make noise before your pads disappear and you have no brakes.
Old Mar 9, 2008 | 06:02 PM
NuRon's Avatar
No, I meant the two V clips to prevent the pads from chattering when you brake. They're different from the clips that hold the pads to the 'mount'.
Old Mar 10, 2008 | 05:51 PM
NuRon's Avatar
bump
Razr2
Mar 30, 2008 08:12 PM
shotgun2224
Oct 9, 2007 11:37 AM
sony224422
Aug 13, 2006 04:30 PM
mr tl
Sep 20, 2002 08:22 PM
