real bad cabin leaks......
Old Mar 8, 2008 | 05:56 PM
blackeg's Avatar
Default real bad cabin leaks......
so today i go outside to find about 2 inches of water on the floor of my drivers side rear seat. and yes, all the windows were up. i also notice water right up between the floor and the rocker panels, under the gas/brake lines. i think its coming in from around the winshield, are there any other typical or common places for leaks?. it seems to be coming from behind my dash and getting onto the floor. the coin pocket left of the steering wheel had water in it too? just looking for places to look before i dump money on a new winshield. thank you
Old Mar 9, 2008 | 08:00 AM
2slow4stock's Avatar
Might be the pillar ruster throught, (Pull the weather stripping up a little on the driver side and see if you can see holes undernear the stripping.
Just my 2 cents
Old Mar 9, 2008 | 08:15 AM
UmbraDc2K's Avatar
Default Re: real bad cabin leaks...... (blackeg)
Another place they say is in the rear hatch.
There's a write up about it here:
https://honda-tech.com/zerothread?id=1958029
Old Mar 9, 2008 | 04:43 PM
Well with the rear hatch leak, there would be water all over the hatch area. There would HAVE to be a lot of rain to fill up the front area.
Oh yeah, i'd check how your door seals are. IF it is a SI check the weather stripping around the sunroof. Another way to check is to go to a automatic washing place or have a friend spray water all over while you are inside the car and find the leak from there. That would be the best idea.
Old Mar 9, 2008 | 05:51 PM
UmbraDc2K's Avatar
Default Re: (2slow4stock)
Well I understand that but he was asking <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">are there any other typical or common places for leaks?</TD></TR></TABLE> so I informed him of that place just so he knew.
citrus3000psi
May 19, 2008 02:52 PM
instructor74
May 18, 2008 09:01 PM
crxforum
Oct 30, 2006 01:15 PM
PatrickGSR94
Jan 14, 2005 07:40 AM
Ronin Integra8
May 25, 2003 08:38 AM
