stock si intake!!! got pic
Old Mar 7, 2008 | 08:21 PM
immajackuup's Avatar
Default stock si intake!!! got pic
Will a stock si intake fit on a d16y8 TB?
Is there a different from stock ex and si including fitments?
The only difference i see is that the ex pipe is smaller and the si is bigger.
But could i still use the stock si intake on d16y8 manifold?
plus before i start pulling off the y7 manifold do i need to drain anything?
Old Mar 7, 2008 | 08:53 PM
994door's Avatar
Default Re: stock si intake!!! got pic (immajackuup)
bigger like you mentioned, but the part that attaches to the mani may be placed in a different spot.
Old Mar 7, 2008 | 09:33 PM
Default Re: stock si intake!!! got pic (994door)
anything?
Old Mar 7, 2008 | 09:48 PM
Blk00EJ8's Avatar
If you're removing the manifold you need to drain your coolant first or else leak it everywhere once it comes off. Why remove the manifold?
The Ex TB is only a couple mms smaller in diameter so it should be alright if you tighten it down with a screw clamp. They both bolt down the same because the chassis are essentially the same.
Old Mar 7, 2008 | 10:07 PM
Default Re: stock si intake!!! got pic (Blk00EJ8)
doing the y7 manifold swap to y8,where would the radiator drain plug be at?
so it should be fine with the si intake.
Old Mar 7, 2008 | 11:05 PM
EK45VTi's Avatar
radiator drain plug is on the mid-bottom of the rad... just under the cooling fan
You also have a block-drain bolt which is placed on the left of the oil filter (looking from underneath)... that one is sometimes very hard to unscrew
Modified by KKVTi at 10:11 AM 3/8/2008
Old Mar 7, 2008 | 11:45 PM
Default Re: stock si intake!!! got pic (KKVTi)
dang i gotta do the block drain too
Old Mar 8, 2008 | 12:13 AM
EK45VTi's Avatar
OOOPS, sorry, my fingers are quicker than my brain
I edited the above post... the block drain bolt is on the LEFT of the oil filter
Old Mar 8, 2008 | 12:18 AM
do i really have to drain the block because i see people just drain the radiator to do the swap.
Old Mar 8, 2008 | 12:44 AM
2oh6civic2's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immajackuup &raquo;</TD></TR><TR><TD CLASS="quote">do i really have to drain the block because i see people just drain the radiator to do the swap.</TD></TR></TABLE>
no you dont have to drain the block just drain the radiator and your golden
Old Mar 8, 2008 | 12:48 AM
EK45VTi's Avatar
No, you don't have to... but it is always a good thing if you're going to use some other brand of coolant...
If you reuse the old coolant or go with the same brand, you don't need to drain the block
Old Mar 8, 2008 | 07:43 AM
Civic98KH's Avatar
it doesnt matter what coolant you use, when i put my skunk2 intake mani on, i only did the rad drain plug not the block, if you have any questions, get at me, either pm me on here, im me on aim (nkrediblechop710) .. or text my cell 4848217606..i will help you out
OAKHILL510
Jan 2, 2009 12:05 PM
immajackuup
Mar 5, 2008 05:33 PM
MobRacing2
Jan 25, 2006 03:12 PM
4DRmafia
May 3, 2005 06:31 PM
