Hondata I/M Gaskets
Old Mar 7, 2008 | 06:23 PM
92'si's Avatar
Default Hondata I/M Gaskets
Hey guys & gals:
Got a quick question, Recent finished my build and reused my hondata I/M gasket... I checked it over pretty good cleaned it up, there was no cracks. But my car idles at a crazy 1300-1700 rpm's. I have stage 2 pro series cams but would they cause it to idle that bad... I don't think so. I checked for vacuum leaks with carb cleaner, and was unable to find any. I'm also using a pro series 66mm T/B that was port matched to a pro series I/M. If that helps any? I'm basicly trying to ask you guys weather or not any one could help me find a potential vacuum leak, and or what is causing the high idle, car runs fine, I know it needs a tune, but car still runs ok for now, i'm getting it tuned at the end of the month after i break in the new motor.
Thanks in advance for any help.
Old Mar 7, 2008 | 06:37 PM
boostedjdmdc2's Avatar
Already checked the obvious IACV and FITV?
Old Mar 7, 2008 | 06:41 PM
92'si's Avatar
Default Re: (boostedjdmdc2)
yessir, sensors good to go. no CEL's
Old Mar 7, 2008 | 08:38 PM
yoffer's Avatar
Banned
Hondata IM gaskets are fine for reuse. You might want to go over all your vacume lines to make sure for a tight fit.
Old Mar 7, 2008 | 11:02 PM
cherroneballs's Avatar
did you turn in the idle adjustment screw on the throttle body? also maybe your throttle cables to tight or the throttles sticking? just simple stuff but throwing ideas your way.
Old Mar 8, 2008 | 09:21 AM
Default Re: (cherroneballs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherroneballs &raquo;</TD></TR><TR><TD CLASS="quote">did you turn in the idle adjustment screw on the throttle body? also maybe your throttle cables to tight or the throttles sticking? just simple stuff but throwing ideas your way.</TD></TR></TABLE>
x2
Old Mar 8, 2008 | 10:17 AM
suno's Avatar
yup, throttle screws!! check those.
GT500FTW
Engine Management and Tuning
Apr 30, 2014 12:58 AM
brokenojoke
Mar 23, 2005 07:51 AM
TurboIntegra
Aug 30, 2002 02:01 PM
Brian_92GSR
Feb 4, 2002 01:00 PM
HX_Guy
Jan 11, 2002 10:41 AM
