What should i replace while tranny's out?
Old Mar 7, 2008 | 05:04 PM
dope's Avatar
Default What should i replace while tranny's out?
Hey i just bought a 98 civic dx, and i'm replacing the transmission. I was wondering what kind of seals or bearings typically go bad and what I should replace. I noticed on the new tranny, when you spin the shaft forward/backward, it kind of clicks....idk if this is normal. Help is greatly appreciated
Old Mar 7, 2008 | 05:12 PM
smileycvc's Avatar
Default Re: What should i replace while tranny's out? (dope)
I would change the clutch and throw out bearing and pilot bearing for sure. Have the flywheel replaced or machined if needed.
Old Mar 7, 2008 | 05:16 PM
dope's Avatar
Default Re: What should i replace while tranny's out? (smileycvc)
alright sweet, i've heard about some sort of main oil seal. Is that a big deal?
Old Mar 7, 2008 | 09:37 PM
smileycvc's Avatar
You can change the main seal, but if its not leaking yet then I wouldnt mess with it, but thats just me.
Old Mar 8, 2008 | 12:25 AM
EK45VTi's Avatar
yes, change the main seal under the flywheel... it costs few bucks, it is very easy to replace...
Also, like someone mentioned above, replace the clutch (plate, disk and the bearing)
Don't foget to apply the high-temp grease... here's the picture where it sould be applied
Old Mar 8, 2008 | 12:40 AM
2oh6civic2's Avatar
* B A N N E D *
Default Re: What should i replace while tranny's out? (KKVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi &raquo;</TD></TR><TR><TD CLASS="quote">yes, change the main seal under the flywheel... it costs few bucks, it is very easy to replace...
x2
Old Mar 8, 2008 | 05:19 AM
jhonda239's Avatar
Default Re: What should i replace while tranny's out? (2oh6civic2)
im going to be replacing my clutch soon so this helped a wee bit
Old Mar 8, 2008 | 05:25 AM
SirRevvs's Avatar
Default Re: What should i replace while tranny's out? (jhonda239)
replace, clutch, pressure plate, pilot bearing, throwout bearing, machine flywheel, replace rear main seal, and easier to replace axle seals with trans out of the car.
DanielP
10
Aug 25, 2017 10:33 AM
94gsr_vtc
Aug 26, 2004 04:57 PM
CircuitFG
Jul 23, 2003 04:56 PM
MechEng
Apr 1, 2003 03:45 PM
RaVAGE00
Jan 26, 2003 06:20 AM
