throttle body and tps
Old Mar 7, 2008 | 07:23 AM
miguel329's Avatar
Default throttle body and tps
is it possible to set the tps on a throttle body without installing it to the car first?i got a blox tb and tps i want to take it somewhere to get preset since im not understanding how you set it thanks..
Old Mar 7, 2008 | 07:32 AM
crazyguy's Avatar
Default Re: throttle body and tps (miguel329)
u can install tps on the throttle body first without installing it to the car but u will need to do the tps adjustment with a multimeter after all the sensors and power sources are connected.
Old Mar 7, 2008 | 08:15 AM
Juan_Mitosis's Avatar
crazyguy is right. Throttle and TPS have to be installed, and everything must be plugged, so you can calibrate the TPS. Its not difficult at all, if you have a multimeter or can ger a hold of one you will be able to calibrate it EASILY in a few minutes.
Oh and. . . search some more next time. Searching for TPS has like a million results with the same explanation over and over, this is the one I used, I hope it helps you too. Good luck!
https://honda-tech.com/zerothread?id=2193100
Old Mar 7, 2008 | 09:24 AM
miguel329's Avatar
Default Re: (Juan_Mitosis)
thanks alot imma try it, yea i ussaully search just was running out the door and its been crazy here today..haha thanks alot guys
integratyper1990
Jul 16, 2009 12:19 PM
turboef90
Mar 23, 2009 10:07 AM
TwoKSiR
Mar 25, 2008 11:11 AM
Integra1990man
Oct 9, 2006 03:32 PM
getzy3
Apr 13, 2005 03:21 PM
