Suspension & Brakes Theory, alignment, spring rates....
type-r swaybar 23mm for civics 92-95
Old Mar 7, 2008 | 06:19 AM
wolferine358's Avatar
Default type-r swaybar 23mm for civics 92-95
i bought a type-r swaybar 23mm bushings and d-brackets from jdmland.com,, but does anyone know how it bolts on,it doesnt seem to fit with the d-brackets.also anyone know where i can see pics of this part,if so thanks ,if not still -thanks.i have a 94 4dr lx with omni power lca's,the ones that have the swaybar attachments.
Old Mar 7, 2008 | 06:50 AM
gabebauman's Avatar
Default Re: type-r swaybar 23mm for civics 92-95 (wolferine358)
The itr bar d-bracket bolt holes are farther apart than the stock civic subframe holes. My suggestion is to get an ASR subframe brace so that you can mount the itr bar. It comes with instructions on how to install.
Old Mar 7, 2008 | 09:55 AM
Weel's Avatar
Default Re: type-r swaybar 23mm for civics 92-95 (gabebauman)
I welded a plate to the subframe, predrilled the top hole to use the exsisting swaybar bracket threaded hole. Then drilled out another hole for the bottom bolt to go through put a plate on the other side of subframe and used a washer and nut. No subframe tear at all as I have strengthened with a welded plate.
Old Mar 7, 2008 | 10:17 AM
thank u guys,does that asr brace really help?or just for looks,still do yous know where i can see some pics on this topic?
Old Mar 7, 2008 | 10:42 AM
94eg!'s Avatar
#1 Super Guy
Loved
It really helps. The ITR subframe is reinforced for the adde stresses of the bigger bar. Without out the sub-frame can tear. This is why the standard civic brackets don't work. At the very least use one of those kits like Beaks or the other knockoffs.
Old Mar 7, 2008 | 12:17 PM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wolferine358 &raquo;</TD></TR><TR><TD CLASS="quote">Do you know where I can see some pix on this topic?</TD></TR></TABLE>
https://honda-tech.com/zerosearch
Your search for ASR returned 24 results. And that's in the new topics. Archived topics have 70 results.
Old Mar 11, 2008 | 02:19 PM
.PLUMMM's Avatar
Default Re: type-r swaybar 23mm for civics 92-95 (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">It really helps. The ITR subframe is reinforced for the adde stresses of the bigger bar. Without out the sub-frame can tear. This is why the standard civic brackets don't work. At the very least use one of those kits like Beaks or the other knockoffs.</TD></TR></TABLE>
x2. ASR for the win! It's a must and it's been proven. I wouldn't, and didn't, settle for anything less
Old Mar 12, 2008 | 06:27 AM
gabebauman's Avatar
Default Re: type-r swaybar 23mm for civics 92-95 (.PLUMMM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .PLUMMM &raquo;</TD></TR><TR><TD CLASS="quote">
x2. ASR for the win! It's a must and it's been proven. I wouldn't, and didn't, settle for anything less </TD></TR></TABLE>
+ it's legal in Street Mod now.
98civdx
Suspension & Brakes
May 15, 2010 10:10 AM
DeDonDeRosa
Apr 1, 2009 06:22 AM
Groove_D
Suspension & Brakes
Mar 20, 2007 06:29 PM
undertheradar
35
May 16, 2006 10:57 PM
Uniden
Sep 2, 2004 01:42 PM
