Installing a C-pillar bar on a 92-95 hatchback?
Re: Installing a C-pillar bar on a 92-95 hatchback? (Uniden)
You have to pull the trim off, and line up the hole on the chassis (where the seatbelt bolt was) with the trim and mark it on the back of the plastic. Then remove and drill.
what i did was, drill a hole and then dremel it out to a circle and test fitted the bracket for the c pillar bar til it fits perfectly and it also depends how you want the bracket to face, upwards, downwards, to the side will determine how the hole gets cut accordingly.
wassup dude i had the same problem too so heres the help that i got
https://honda-tech.com/zero...10506
check it out you but the hatch not mines ok its was sumbody els im not hating or anything
Driven
03-27-2003 08:25 AM
AK94GSR
46
01-06-2003 01:21 PM
