B16a into 3g Integra can someone help??!!!...
need some help , what mounts need to be changed or is it all right to use the b16 stock mounts. i know i have to change the side mount on the timing belt side can ne one help or give me a resource page for b16 into 3g integras
yeah why?? anyways what year b16 is it?? if its 2000 si b16 then you need to get the 2 top mounts and rear bracket. also gsr driver side motor bracket
just so i can sell the car its a b16 95 jdm motor in a 3g integ and the motor was a deal
what mounts are needed or need to be changed ?
besides the side bracket
[Modified by nosmas, 10:13 AM 7/8/2002]
[Modified by nosmas, 5:53 PM 7/8/2002]
if you are using second gen B16A, then reuse the stock mounts....all should bolt up... (2nd gen b16a came with two types of mounts on the driver side - 92-3 d-series offset and 94-5 d-series parrallel)
otherwise just bolt on your b18b mount to the block and be done...
for 1st gen b16a, electronics, mount, 02 sensor, thermostat housing with sensor, bottom mount added
LD_EGSICK
May 10, 2004 05:35 AM
hyper em1
Apr 21, 2004 06:34 PM
90CIVICSI
Jan 15, 2002 08:17 PM
