Suspension & Brakes Theory, alignment, spring rates....
cheap upgrades
Old Mar 6, 2008 | 08:15 PM
WillEat4F00d's Avatar
Default cheap upgrades
First off, I have a 97 Accord 4-cyl. I just wanted to know what are some basic, suspension wise, things I could do to the car. I don't want to do anything spectacular, just a little something extra. Thx.
Old Mar 7, 2008 | 09:56 PM
laocivic's Avatar
Default Re: cheap upgrades (WillEat4F00d)
springs n sway bars. if u wanna b slammed go coilovers(cheap ones will ride like ****). i've used ebay springs and they've gone 50K plus miles with no problem.
Old Mar 7, 2008 | 10:16 PM
blinx9900's Avatar
Default Re: cheap upgrades (laocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic &raquo;</TD></TR><TR><TD CLASS="quote"> i've used ebay springs and they've gone 50K plus miles with no problem.</TD></TR></TABLE>
i prefer cut stock springs and cut bump stops over ebay springs anyday.
Old Mar 8, 2008 | 12:04 AM
laocivic's Avatar
Default Re: cheap upgrades (blinx9900)
to each his own...ur way is free and rides just as good. so yea cut them bitches. but beware ur shocks will go pretty quick
Old Mar 8, 2008 | 12:33 AM
Elwuudz's Avatar
springs are a great way to go, stiff progressive rate would be desireable
I would prefer some TEIN flexes or some Koni yellows andGC's
It will be a different car either way
High performance handling by motorbooks is a good reasource to give some goo info about what will give you best results; bang for the buck etc...
Modified by Elwuudz at 7:47 PM 3/8/2008
Old Mar 8, 2008 | 07:18 PM
If I was to get some springs, would I also have to buy something else to go along with it. Would the stock suspension work well along with the springs? Thx.
Old Mar 11, 2008 | 06:50 PM
I've read from the FAQ that the Eibach ProKit springs are good for stock suspensions. Are there other recommendations out there as far as springs for stock suspensions?
Old Mar 12, 2008 | 08:45 PM
Default Re: (WillEat4F00d)
If I could only upgrade one thing, which should I get first, shocks or springs? Which would you recommend? I don't need anything fancy since this is car is a driven daily, with about 80 miles on the highway each day. I am not gonna take it to the track, autox or anything, just using it on the streets. Thx.
Thomas Williams
Sep 10, 2012 08:58 AM
Masho
10
Apr 2, 2012 11:48 PM
kwizical
Jan 14, 2008 03:41 PM
DB1_559
Suspension & Brakes
Dec 2, 2005 01:35 PM
DB1_559
Suspension & Brakes
Nov 18, 2005 08:19 PM
