need help with friends car doing a weird idle problem
Old Mar 6, 2008 | 06:45 PM
asianrepnsb's Avatar
Default need help with friends car doing a weird idle problem
two of my friend has the same problem with there car and we dont know why just need some trouble shooting ok when car is idleing it goes room room room like repeatly we change map sensor we change new trottle change tps sensors and we looked to see any vacumm lines was disconnected and it still doing the same thing and we dont know why its doing it please some help trouble shoot
Old Mar 6, 2008 | 07:31 PM
jdmpower363's Avatar
i have a simular problem. ppl always say its the iacv, but i still have no luck. good luck figuring it out. sure youll here the same things i have.
Old Mar 6, 2008 | 07:36 PM
97Ej6mike's Avatar
the IAVc is the culprit for most, or any idle issues. The FITv can be a problem as well.
Old Mar 6, 2008 | 07:39 PM
Former User's Avatar
Default Re: need help with friends car doing a weird idle problem (asianrepnsb)
Try bleeding the cooling system of air bubbles. As jdmpower363 suggests, cleaning the IACV with carburetor cleaner is also worthwhile.
Otherwise, check for intake air and vacuum leaks by spraying carburetor cleaner around vacuum hoses, throttle body, and intake manifold. If there's a leak, the engine should bog.
Old Mar 7, 2008 | 08:05 AM
Default Re: need help with friends car doing a weird idle problem (RonJ@HT)
thanks for the help everyone ill try it out and see what it does thanks....
Old Mar 7, 2008 | 09:58 PM
db1st's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asianrepnsb &raquo;</TD></TR><TR><TD CLASS="quote">two of my friend has the same problem with there car and we dont know why just need some trouble shooting ok when car is idleing it goes room room room like repeatly we change map sensor we change new trottle change tps sensors and we looked to see any vacumm lines was disconnected and it still doing the same thing and we dont know why its doing it please some help trouble shoot</TD></TR></TABLE>
ok guys...this is what you should first...unbolt your throttle body(drain coolan a little first so you won't make a mess) and remove the Fast Idle Valve(FIV). check the Fast Idler Valve and check if the spring inside that controls the valve operation is still good...if it is still good....then unbolt the Idle Air Control Valve(IAC). it has to be either or both, so....good luck. the reason why i suggest that you check the FIV first is because, it's cheaper than the IAC. you don't wanna buy a IAC that cost over $250 and find out that it's the FIV...which cost $150
let us know!!!
Old Mar 7, 2008 | 10:37 PM
obuhmyuh's Avatar
Default Re: need help with friends car doing a weird idle problem (db1st)
also make sure you dont have any plugs backwards, or in the wrong place period. the TPS and MAP sensors are identical except the color of the wires and are often mixed up. TPS has a red/blue wire in the center. Also check and loose/damaged/missing grounds...
Old Mar 7, 2008 | 11:58 PM
cherroneballs's Avatar
wow alot of these idling problems lately. most of the time it's a vaccum leak some where. take some carb cleaner and spray it around the intake manifold and vaccum lines. small spots at a time though so you can pin point the prob. if the motor revs up you found the prob.
Old Mar 7, 2008 | 11:59 PM
also try to disconnect the iacv on the back of the intake manifold while the car is running and if theres no change theres a good poss. that the iacv is bad.
Old Mar 8, 2008 | 12:28 AM
Killer Kham's Avatar
Here is a very HELPFUL link. Read more then twice or so for better explanatory.
http://www.dc425.org/myhonda
http://www.ef-honda.com/ben/Badidle.php
https://honda-tech.com/zerothread?id=1564019
https://honda-tech.com/zero...age=1
ENJOY!!
Old Mar 8, 2008 | 08:52 AM
ek4_b16a's Avatar
Default Re: need help with friends car doing a weird idle problem (Killer Kham)
i was also told that the other reason behind all these idling probs is cause you guys keep over redlining your car...for the ls motors pretty much...it is the iacv most of the time...well yea...check all the above
Old Mar 8, 2008 | 09:01 AM
egwhte's Avatar
good info!
im try these out.
Old Mar 8, 2008 | 12:26 PM
Default Re: (egwhte)
your welcome
killahatch
Apr 12, 2009 07:44 AM
xxh3iiraz0rxx
Feb 19, 2008 04:36 PM
rice a roni
12
May 24, 2005 12:31 PM
hyperlite1080
Apr 19, 2004 06:56 PM
fast4w$
Jan 9, 2004 10:04 AM
