which half shaft having alxe binding up
i have a 1994 civic b16, i have integra axles... which half shaft do i need like the stamped number not which year and make.
thanks
thanks
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si90rex »</TD></TR><TR><TD CLASS="quote">i have a 1994 civic b16, i have integra axles... which half shaft do i need like the stamped number not which year and make.
thanks
The 94-01 integra or 99-00 si or DEL SOL VTEC axles will work. No idea what the part number is. You probably seperated the axle trying to put it in.
Lemme guess. It's an aftermarket axle, you just put it in, and you pulled on it slightly while installing. It is now jiggling and wiggling on the inside joint as it rotates.
Am I correct?
thanks
Am I correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
Am I correct?</TD></TR></TABLE>
NO, i'm not stupid! i had a crx with the b16 took it to the track, on the lunch i snapped the shaft on the axle in between joints in half and wripped the motor mount off the frame ....bougth this car and it came with axles and tranny....it pulls to the left hard and couldn't figure it out got it aligned and the frame checked.. both good... i changed axle and wanted to make sure i had the right intermedate shaft... but i put a new axle in tonight and its fixed it...
