what axles
Re: (95civiccpdx)
get them for whatever motor you plan on putting in.. i used to think all b's were the same but i had an issue with a half shaft that was female and so was the drivers side axle so i had to start the search and found out there are some variations so just stick with the axles from whatever motor you are installing
Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">94-01 Integra, 99-00 Civic Si, 94-97 Del Sol VTEC</TD></TR></TABLE>
Re: (95civiccpdx)
go to autozone or whatever your local parts store is and tell them you need axles for a 94 integra ls. and if your car has abs then get abs if not then dont. you should be good to go
Re: (95civiccpdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civiccpdx »</TD></TR><TR><TD CLASS="quote">alright 1 more ?? will the 91 halfshaft fit with 94 axles or i need a new halfshaft??</TD></TR></TABLE>
If you have a 91 halfshaft, you will need 90-93 Integra axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civiccpdx »</TD></TR><TR><TD CLASS="quote">alright 1 more ?? will the 91 halfshaft fit with 94 axles or i need a new halfshaft??</TD></TR></TABLE> forgot to ask if you had a 91 half shaft. i just assumed and that makes an *** out of everyone huh
