Clutch slipping during warm/ hot weather
Old Mar 6, 2008 | 07:42 AM
oneprelude's Avatar
Default Clutch slipping during warm/ hot weather
My clutch slips when I drive for a while in warm/ hot weather. Car runs perfect in the morning, but once it heats up, then the clutch starts slipping. Any reason for this?? I'm running OEM Exedy clutch with lightweight Fidanza flywheel
Old Mar 6, 2008 | 01:05 PM
BeyondTheCompetition's Avatar
Default Re: Clutch slipping during warm/ hot weather (oneprelude)
Time to replace the clutch would be my best guess...mine did the same thing when it was getting worn...
Old Mar 6, 2008 | 02:04 PM
M@'s Avatar
M@
Default Re: Clutch slipping during warm/ hot weather (BeyondTheCompetition)
how old is the clutch? Miles?
Old Mar 6, 2008 | 02:28 PM
oneprelude's Avatar
Default Re: Clutch slipping during warm/ hot weather (M@)
I would say no more than 20k miles
Old Mar 6, 2008 | 03:12 PM
flight50's Avatar
are you sure its when it warm/hot weather vs a warm/hot motor. i had this problem....til i figured out what it was. after 20k it shouldn't be doing this. did you change your seal at all or even look at it if you changed your clutch yourself. the problem i had was that my seal leaked and once the motor got hot, the oil got thinner and hotter which allowed it to bypass the main seal and on get to my clutch disk.
Old Mar 7, 2008 | 03:13 PM
M@'s Avatar
M@
Default Re: Clutch slipping during warm/ hot weather (flight50)
That could be. I was thinking you might have the clutch pedal too tight. This would prevent the clutch master cylinder from relieving pressure when the pedal is all the way out. If that makes sense.
Old Mar 12, 2008 | 01:35 PM
oneprelude's Avatar
So, all I need to do is to replace the seal, right??
Old Mar 12, 2008 | 01:38 PM
vlang29's Avatar
depends on the condition of your clutch. If you've been slipping for a long time, it's probably pretty burnt up
Old Mar 13, 2008 | 08:54 AM
flight50's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneprelude &raquo;</TD></TR><TR><TD CLASS="quote">So, all I need to do is to replace the seal, right??</TD></TR></TABLE>
don't know. you have to break it down to find out the exact cause. but with 20k on it, the seal is my guess. my clutch went out with 60 miles on it but it was due to my seal. some replace clutch at 80k+. but thats because the clutch is worn. your driving habits has a factor in that part.
DC5KING
42
Feb 22, 2017 08:31 AM
s13hero
14
Nov 21, 2010 04:57 PM
mattmw88
Apr 23, 2008 09:57 AM
InitialJRift
Sep 13, 2006 10:43 AM
SiYouLater
May 23, 2004 11:35 AM
