Which Ecu Should I run?
Old Mar 5, 2008 | 09:28 PM
boostedjdmdc2's Avatar
Default Which Ecu Should I run?
well im running an obd1 JDM b16 that was wired to run a p2t (2000 si ecu), just picked up a obd2b to obd1 jumper harness, and now im running a chipped p30 that i borrowed from a buddy of mine. my car was running kinda rough with the p2t because my secondary 02 was malfunctioning and it was throwing a CEL. now that im running the obd1 p30 it doesnt throw any CELs but was wondering if running a stock p30 or a chipped p28 would be better. noticed with the chipped ecu that my gas mileage has gone down a little because it wasnt orignally meant for my b16. any input?
Old Mar 5, 2008 | 09:33 PM
qkcivic's Avatar
Default Re: Which Ecu Should I run? (boostedjdmdc2)
I ran a chipped p28 with the conversion harness on my b16a2
Old Mar 5, 2008 | 09:49 PM
SirRevvs's Avatar
Default Re: Which Ecu Should I run? (qkcivic)
is your car obd1 or obd2. if it's obd1 the correct ecu would be a p30 or yes you can use a "chipped" p28 but that's ghetto imo. If its obd2 then you can run an obd2 p30 or a P2T si ecu. A JDM PCT or P73 ECU would run the engine best if you're obd2 but in most states you won't pass emmissions testing because usdm obd2 testing equipment won't read a jdm ecu.
Old Mar 5, 2008 | 11:08 PM
em1gangsta's Avatar
Default Re: Which Ecu Should I run? (SirRevvs)
i use a chipped p28 on my 2000 em1 si. it works fine and no cel. id go with that.
Old Mar 6, 2008 | 01:15 AM
crazyguy's Avatar
chipped p28 ecu
Old Mar 6, 2008 | 11:37 AM
SirRevvs's Avatar
Default Re: Which Ecu Should I run? (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">chipped p28 ecu </TD></TR></TABLE>
TUNED P28 ECU "chipping" is for when you're 16 and you want mad sounding vtak!
Old Mar 6, 2008 | 09:59 PM
well my car is obd2, and i passed emissions with it obd2 a couple months ago when i was running the p2t.
sounds like a p28 with a chip then would be best?
Old Mar 7, 2008 | 06:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">
TUNED P28 ECU "chipping" is for when you're 16 and you want mad sounding vtak!</TD></TR></TABLE>
lol bump
Old Mar 7, 2008 | 06:30 PM
92'si's Avatar
S300!! got it and havent looked back since
Old Mar 7, 2008 | 07:23 PM
Somnambulist's Avatar
I agree with SirRevvs. A DOHC ECU will run the car better than a chipped SOHC one..
P30 gets my vote.
Old Mar 7, 2008 | 09:23 PM
laocivic's Avatar
Default Re: Which Ecu Should I run? (Somnambulist)
i say get the ecu for that motor. or if ur gonna go p28 atleast get a b16 basemap
Old Mar 7, 2008 | 10:02 PM
jax97hx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92’si &raquo;</TD></TR><TR><TD CLASS="quote">S300!! got it and havent looked back since </TD></TR></TABLE>
Ive tuned with it on buddies cars and it is amazing but not all of us have the change to drop on it
one of theses days tho, ill get mine
Old Mar 7, 2008 | 10:09 PM
jax97hx's Avatar
Default Re: Which Ecu Should I run? (jax97hx)
o yeah tuned p28 with crome here
JDMfan77
23
Jun 26, 2010 11:38 AM
blacc_ej1
Jun 7, 2009 08:19 PM
teamvirus
Sep 20, 2006 09:41 PM
hYbRid_Eg6
Jul 31, 2005 09:36 PM
fatalman
Dec 22, 2003 06:50 PM
