mini me gone haywired!!! please help
if anyone can help me it be greatly appreciated.
i have 2 speared motor and a chassis, so i decided to do a mini me. but now i can't started the damn thing. it cranks but won't turn over. it will try too but it will start to pop like miss firing nosies. i have a 1994 honda Del slow with a d16z6 and a 89 crx motor d16a6.the block on the Del so lose compression so i decide to do the mini me with the A6's block,i use a vtec head gasket with a vtec timing belt. the cars an auto with a auto ecu p28. is there anything else i need to replace or do or modified to complete the swap. i'm soo lose now. i checked everything and there all in spec. firing order,timing 17 times,fuel is all there,actually it's flooding a little from cranking the car hahah but i cleaded it already. so please if there's is a mini me guru out there please save my sorry *** this one time thanks agian to who ever reply
Modified by integra01 at 11:41 AM 3/6/2008
if it dont start u missing a ground or ur timing is off my timing was off by alot and wouldnt start but im still in the same boat cuz i cant get it to sound right also with a a6/z6 mini me u have to use y7 cam gear. my **** backfires and is boggy
so is the y7 cam gear smaller or larger, and is it possiable to off set the z6 cam gear to compenate for the timing and what car does a y7 cam gear come from
this is just a suggestion not sure if im right but it maybe the main relay my buddy had this problem and the relay was the solution
I was using hte stock Z6 cam gear and it was fine on my set up...I was running a D15b2 block with a Z6 head. my guess is you either didnt convert to OBD1 properly. or you are running a Z6 distributor and still didnt modify anything to account for that.
tell us what kind of distributor and intake and what OBD0 or OBD1 you are running? I know you are running a P28 so did you convert everything over to OBD1? like your injectors, etc?
alright well this is how it is right now. i have a stock 1992 honda del so with a d16z6 on it. but the block was blown and i had a 89 honda crx which is a d16a6 motor and decided to do a mini me cause i had the 2 piece to make a good mini me right. a6 with a z6???? so long story short i change the head gasket to a z6 along with a timing belt. this is all i changed on the the car : block, HG, timing belt. everything else is the same on 16z6 ie manifold,ecu,dizzy.etc
when i did my mini me on my rex i had the same problem. make sure ur plug wires are in the corect spot on the dizzy. after you do that and it doesnt start make sure all ur grounds are on even the smallest ground can cause problems. if it still doesnt start take out the spark plug closest to the driver cyl#1 put a long screw driver in there and move the crank till that piston is to the haiest it will go right before it goes back down. then with a white out mark the very top of the crank to indicate top dead center. ok ur block is tdc now take of the timing belt by loosining the tensioner then after that take it of the cam pulley. after you get it off you can time the head by using the marks on the pulley it will say top and it will have lines arount the pulley.there is a back plastic cover behind the pulley where when you get the cam to have the word up, up obviously one line should line up with the back plastic cover. after that make sure the block hasnt mooved and put the timing belt still being carefull that the crank doesnt move. tension it properly. after you put it back together move the crank by hant to make sure it doesnt hit the valves. if everithing is good try to start it. if it doesnt adjust ur valves to specs. let me know what happens after everything.
also use the z6 timing belt
i didnt do that tdc part when i did my vtec conversion, put it still started up, that means i was lucky then right?? haha.. it turned off after but i was missing a sensor that went to the throttle body, thats why
Try taking off the dizzy, align the cam with the #1 on the dizzy than reinstall the timing belt. When doing a minime conversion, dont go by the TDC
DelSols-plural
Sep 29, 2011 01:19 AM
