2000 civic si fuel problems PLEASE HELP!!!
Old Mar 5, 2008 | 05:35 PM
sh_or_ty's Avatar
Default 2000 civic si fuel problems PLEASE HELP!!!
Like the title says, I have a 2000 civic si (125,000). Within the last 5,000-10,000 it has not been running right. Approx. 10,000 miles ago, the check engine light came on and the car was running really rough. I took it to AutoZone for the free diagnostic and they said cylinder 2 was miss firing. I replaced distributor cap, rotor, all four injectors and fuel filter and still a check engine light. Then one day I was driving it and the light went off (problem solved). Since then, the light has come on several more times and it was fixed with a bottle of fuel injection cleaner. A couple of days ago, the light came on again, and this time it's flashing. Cylinder two is not getting any fuel. I spoke with Honda and they said I need a A12 ecu, well my car has one already.............so I'm stuck, what do I do, any ideas, anyone ever had this type of problem?
Old Mar 6, 2008 | 02:09 AM
sh_or_ty's Avatar
Default Re: 2000 civic si fuel problems PLEASE HELP!!! (sh_or_ty)
anyone????????????
Old Mar 6, 2008 | 03:49 AM
B16B_coupe's Avatar
HRD PKR
So have your checked yourself to see if its getting fuel or no??
Try a friends ecu???
I think thats what they are telling you.. is that your ecu is bad...
Old Mar 6, 2008 | 05:41 AM
draneusmc's Avatar
Default Re: 2000 civic si fuel problems PLEASE HELP!!! (B16B_coupe)
give me the ECU error code and we'll go from there...
Old Mar 6, 2008 | 06:11 PM
sh_or_ty's Avatar
Default Re: 2000 civic si fuel problems PLEASE HELP!!! (draneusmc)
i'll get it tommorrow
Old Mar 6, 2008 | 06:12 PM
sh_or_ty's Avatar
It runs rough and when i disconnet #2 injector, it doesn't change at all
Old Mar 7, 2008 | 07:01 AM
sh_or_ty's Avatar
for clarification, the dealership thought I had the A11 ECU and I needed an A12, but I have an A12. Autozone did another check today,
cylinder 1 and 2 misfire
Old Mar 7, 2008 | 09:08 AM
Somnambulist's Avatar
What did you plugs look like? Might wanna try replacing them?
X2 on the bad ECU part. I just had one go out in my car..
Old Mar 7, 2008 | 09:37 AM
Former User's Avatar
Default Re: 2000 civic si fuel problems PLEASE HELP!!! (Somnambulist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Somnambulist &raquo;</TD></TR><TR><TD CLASS="quote">What did you plugs look like? Might wanna try replacing them?
As you already have a new cap and rotor, your next attempt at solving the misfire problem should be to replace the plugs and wires.
Old Mar 7, 2008 | 12:38 PM
sh_or_ty's Avatar
plugs and wires have both been replaced...........
Old Mar 7, 2008 | 01:52 PM
2000siturboR's Avatar
try a compression could be bad rings i had same problem misfired in every cylinder
Old Mar 10, 2008 | 06:29 PM
sh_or_ty's Avatar
Default Re: 2000 civic si fuel problems PLEASE HELP!!! (2000siturboR)
did a compression test, #2 cylinder is at 50-60.........................where do I go from here?
Old Mar 10, 2008 | 07:28 PM
urnotfast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh_or_ty &raquo;</TD></TR><TR><TD CLASS="quote">did a compression test, #2 cylinder is at 50-60.........................where do I go from here?</TD></TR></TABLE>
go to the bank and make a withdrawl.........................you are about to need it. those numbers are and you need to find the cause. good luck bro
Old Mar 12, 2008 | 10:19 PM
like what he said make a large withdrawl and start taking it apart im guessing fried cylinder torched the rings loss on compression and causeing to miss i had same problem only mine was all 4 and number 2 had 0 compression.
Old Mar 13, 2008 | 06:46 AM
sh_or_ty's Avatar
it's in the shop getting a b18c, thanks for everyone's help.
FSOSK
Feb 12, 2007 03:28 AM
5thgensedan
Mar 21, 2004 05:44 PM
Cyrio
Aug 22, 2002 07:57 AM
