will bad struts cause camber?
well i have a camber kit already and i wanted to know cause im getting an alighnment tommrow..and i have bad struts i was wondering if that would affect it even after i got an alighnment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shizkabob3421 »</TD></TR><TR><TD CLASS="quote">like the tittle says will bad struts make your car camber worse..or is it all about the alignment?
thanks.</TD></TR></TABLE>
not really, atleast it hasn't happen to my wifes saturn. she blew the strut and has been driving like that for over a year, along with no alignment for over a year and the tires are good, no signs of premature wear.
The springs/coilovers are much more likely to screw up the ride height and therefore camber.
A blown shock just removes the dampening and added resistance to shock, the spring is where most of the weight is carried on. An old bent/sagging/cut spring may cause this, but a blown strut will likely have a minimal effect on your camber.
ok i have neuspeed springs like 2.5 in drop on stock struts it was like that when i bought the car and im 17 and no job so i have no money to replace struts..and it is just eating tires all my friends have been donating steelies to me forever and now i have enough money for a alighnment so i hope that helps with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shizkabob3421 »</TD></TR><TR><TD CLASS="quote">ok i have neuspeed springs like 2.5 in drop on stock struts it was like that when i bought the car and im 17 and no job so i have no money to replace struts..and it is just eating tires all my friends have been donating steelies to me forever and now i have enough money for a alighnment so i hope that helps with it.</TD></TR></TABLE>
most likely the whole time you had a bad alignment. get the alignment then find a way to save up for some struts. mow some yards if you need to!
ok thanks alot for the help..ahha yea ive been stripping like copper wire..for money cause we just rewired our house i got some cash for axles a few mounths ago..now i should have enough for an alighnment!
da9pwnsu
Sep 26, 2005 05:21 AM
