trouble with windows
Old Mar 5, 2008 | 02:30 PM
pliskin8's Avatar
Default trouble with windows
i have a '97 ek with power windows. right now i'm having a really big problem with the driver side window, it keeps jumping out of it's tracks, and i keep having to disassemble the door to fix it, if anybody has any suggestions please let me know!
i added lubricant to the 2 rubber raillings on each side of the door and it worked for a couple of days, but it keeps doing it , should i just buy new ones or is there anything else i can do
Modified by pliskin8 at 3:13 PM 3/15/2008
Old Mar 6, 2008 | 08:10 AM
j_po2008's Avatar
Default Re: trouble with windows (pliskin8)
Try spraying some lub. in the rubber pieces where the window goes when its up that should work...
Old Mar 6, 2008 | 08:13 AM
JDM_SOHC's Avatar
Default Re: trouble with windows (j_po2008)
sounds like the retaining bracket on the inside isnt secured or something.. check to make sure everythings tight an in place when u have door apart... theres a writeup on here that someone did when converting their car to power everything an he had some in depth info on the windows an tracks an all that ****....
quique29
Mar 29, 2014 11:00 PM
Tomas P
Apr 6, 2012 12:06 AM
