Wheel Bearing?
Here is my problem it just happened today. I just recently bought an 1998 Acura Integra GS with ABS for $1000. My problem just occurred while driving on the 676 to Chinatown and all of the sudden I hear a loud roaring vibrating sound from the driver side. I looked in the search and most say it is a bad wheel bearing or axle. My car symptoms vibrating and knocking sound from wheel and small noticeable clicks while going over small bumps. I stopped the car on the emergency lane so I wouldn't damage anything else to it and now the car is parked in front of the drive way thanks to a cheap tow.
Is there any test to see which is bad the axle or wheel bearing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Jack the offending wheel off of the ground. Rotate it to check for catching. Twist it side to side and up and down. A bad wheel bearing will cause play.</TD></TR></TABLE>
x2....the way to diagnose for a bad wheel bearing
Checked the wheel today and there was a good amount of play. I took of the Knuckle and bought a wheel bearing from advance auto parts now going to get it pressed in from a shop. Thanks for the help!
DIY
