ZC motors?
There's a few different ZC's.
Sohc Non V-Tec 1.6L is pretty well a d16a6 (stock ef si motor) with a little more aggressive cam in it. Not a bad little motor and easy to build consider mostly all d16a6 parts will work on it.
There's a dohc 1.6L that is pretty well the d16a6 block so to say with a dohc head and I beleive a little higher compress.
And finally the sohc 1.6L v-tec, which if I remember has higher compression.
These are all "jdm" motors and the correct ecu's for them tend to bring out there fully potential unless you plan on doing a tune of some sort.
Hope this helps out any
PM me if you have anymore questions. I've got a bunch of sites that are very zc informative on my other computer that I can send ya.
Civic Hx-T
34
Jun 17, 2016 09:29 PM
AK94GSR
Sep 25, 2006 08:57 PM
