CEL P1456 and P1457
Old Mar 4, 2008 | 03:06 PM
TunerN00b's Avatar
Default CEL P1456 and P1457
Car is a 2000 GSR. No engine mods other than an AEM CAI, which has been on the car for years without issue.
So, for the last 2 weeks, my car has been throwing CELs randomly. Seems to alternate between P1456 and P1457. Happens every couple of days, then I check and clear the codes, then it comes back a few days later.
https://honda-tech.com/zerothread?id=978933
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by https://honda-tech.com/zerothread?id=978933 &raquo;</TD></TR><TR><TD CLASS="quote">
P1456 Evaporative Emissions (EVAP) Control System Leakage (Fuel Tank System)
P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
Er, suggestions on things to check and replace?
Old Mar 4, 2008 | 11:48 PM
Turbo B18C EJ6's Avatar
Default Re: CEL P1456 and P1457 (TunerN00b)
I had that code give me a lot of trouble a couple years ago. first i would check would be the gas cap. is it after market or stock? then i would check all vaccum connections from the intake to evap canister. I would also highly recommend a helms manual. could be anything from leaking hose to a bad purge soleniod. feel free top ask if you have any questions.
Old Mar 5, 2008 | 12:40 PM
TunerN00b's Avatar
Default Re: CEL P1456 and P1457 (Turbo B18C EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo B18C EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">I had that code give me a lot of trouble a couple years ago. first i would check would be the gas cap. is it after market or stock? then i would check all vaccum connections from the intake to evap canister. I would also highly recommend a helms manual. could be anything from leaking hose to a bad purge soleniod. feel free top ask if you have any questions. </TD></TR></TABLE>
Stock gas cap. To my knowledge, the original that came on the car 8 years ago. I'll replace it, and see if it continues.
I can check vac hoses. Whats a purge solenoid?
Old Mar 6, 2008 | 06:35 PM
TunerN00b's Avatar
I hate to bump, but...
All vac hoses are fine. No issues there.
What is a purge solenoid?
Old Mar 8, 2008 | 12:54 AM
Purge solenoid is basically and electrical switch controlled by the ecu to open and close. its mounted on your fuel rail has one black plug into it and two vaccum lines coming from it. one goes to your intake manifold amd the other end to your evap canister mounted on the firewall. How it works is while your engine is running fuel vapors build up in the fuel tank and its stored via a line form the tank into the canister. It gets absorbed by the charcoal in the canister and what is left over stays in. When the ecu see's excess pressure build up in the system from the fuel tank pressure sensor. The ecu then sends a voltage signal to this valve allowing fuel vapors to go into your intake and engine to be burned. And with this not allowing vapors to enter the air. well i hope that helps u understand the system some. thats just a brief description, but hope understand it better now. now for the problem , its hard to fix with out a manual but u cant try to and check all your electrical connections and getting a hold of a helms would help greatly.
Old Mar 10, 2008 | 11:34 AM
TunerN00b's Avatar
Excellent. Very nice description. Thank you.
Yes, a Helms is on the "to buy" list, just haven't got around to it yet.
Old Mar 10, 2008 | 09:33 PM
bbunz's Avatar
nice descriptin
Old Mar 11, 2008 | 08:36 AM
HONDAPARTSMANMIKE's Avatar
theres a acura service bulletin for the evap bypass solinoid valve going bad. heres a quick check you can do locate the evap bypass solinoid valve with the key on,unplug the connetor to it an plug it on and off you should hear a clicking type noise, but first you would have to have power to the valve from either pcm/ecu or apply power or ground. becareful doing this with the connector plug in you could damage pcm if you apply power or ground to the wrong wires. it can be costly i've done it before its sucks. if the valve clicks it possible it could still be bad.good luck (use a repair manual or electrical manual for your car).
DIESEL5
23
Aug 3, 2010 06:21 PM
iheartDc2
Feb 4, 2006 08:26 AM
STubs5000
Nov 2, 2005 05:42 PM
Ideal
Jul 16, 2005 06:31 AM
SIMATIC
Nov 8, 2004 05:11 AM
