18x8.5 +45 offset What size tires?
Old Mar 4, 2008 | 08:09 AM
bald's Avatar
Default 18x8.5 +45 offset What size tires?
i just traded in my Rx-8 for and '04 RSX Type S, and i have the wheels from the Rx-8 that i would like to put on. there aren't too many people on here that use 8.5" wide wheels, and was hoping someone had some input on this.
clursx suggests 235/40/18's, but that seems a little wide-
http://forums.clubrsx.com/showthread.php?t=368629
is anyone personally running or has run 8.5" wheels on a moderately lowered RSX that has helpful input?
CLIFFNOTES: i have 18x8.5" wheels. What tires?
Old Mar 4, 2008 | 08:39 AM
Todd00's Avatar
I said I don't want a title!
Default Re: 18x8.5 +45 offset What size tires? (bald)
Why not sell the wheels and get something more realistic, like a 17x7.5" wheel or something?
While you can make that wheel fit, it's gonna rub. And with a 8.5" wide wheel, you need wide tires to go on there, probably at least a 225 with a 235 being better.
Do the math on your own:
http://www.1010tires.com/WheelOffsetCalculator.asp
Stock 02-04 RSX-S wheel is 16x6.5" +45.
Basically you're looking at 25mm less on the inside and outside.
Old Mar 4, 2008 | 08:51 AM
bald's Avatar
they're gram light 57F's, and i would like to keep them if they don't fit like complete ***. i don't want to go through the hassle of selling them because you always lose money and waste time with flaky buyers.
i've seen a couple people on here that run this size, that's why i wanted to hear from someone that has done this before.
Old Mar 4, 2008 | 09:33 AM
blueshark123's Avatar
Default Re: (bald)
I would go with a 235/40/18 which will give you about a 25.4 diameter. You still might have to get the fenders rolled.
Old Mar 4, 2008 | 11:27 AM
mymomsdrunk's Avatar
Default Re: (blueshark123)
i have the same size on my car, use 225 40's, also i didnt have to roll any of my fenders. they fit perfect
Old Mar 4, 2008 | 04:12 PM
bald's Avatar
also, if you're running 8.5" wide wheels, can you put what suspension you're using? thanks
Old Mar 4, 2008 | 05:17 PM
Default Re: (bald)
well im going to be running bc n+'s, i wont know how everythings going to work out until april, i still have the sways and arms to buy yet.....
last summer i had skunk2's in the front and megan racing's in the rear.
Old Mar 4, 2008 | 08:53 PM
NTCustoms's Avatar
with an 8.5" wheel, use a 235. it fills in the tire very well and makes the most out of the contact patch.
Old Mar 6, 2008 | 02:22 AM
FutureITR's Avatar
Default Re: (NTCustoms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms &raquo;</TD></TR><TR><TD CLASS="quote">with an 8.5" wheel, use a 235. it fills in the tire very well and makes the most out of the contact patch.</TD></TR></TABLE>
Samuels
Honda CR-V & Element
Feb 17, 2013 03:30 AM
Sean @ ESG
Nov 26, 2008 07:32 PM
silverSOHC
Jan 3, 2007 12:00 AM
Craigp23usa
Dec 11, 2006 05:38 PM
nc-rsx-s
Jan 16, 2002 02:49 PM
