tps problem! Help
Old Mar 4, 2008 | 07:16 AM
hotazztegra's Avatar
Default tps problem! Help
For some reason when i drive past 7g the tps kicks in. Would it not having a gasket on it make it do that? Well if anyone could help me let me know. Its got a vic X intake manifold, 70mm thottle body so if that has to do with tps please fill me in.
Old Mar 4, 2008 | 07:20 AM
crazyguy's Avatar
Default Re: tps problem! Help (hotazztegra)
tps is just to control the throttle/pedal position to let computer know when it is idel and when it is full throttle so computer can supply with acurate fuel/air. and what do u mean kicks in? tps doesnt kick in. vtec does and yes it does need/have a gasket to goes on the throttle body. and i dont really quite understand your question. if u have removed tps and reinstalled it to the new throttle body. u will need to perform a tps adjustment with a multimeter.
Old Mar 4, 2008 | 07:50 AM
vtec kicks in fine but when it go above 7 grand the check engine light comes on with tps code. So i think i do need a gasket ima try that first and see if that helps
Old Mar 4, 2008 | 07:51 AM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotazztegra &raquo;</TD></TR><TR><TD CLASS="quote">vtec kicks in fine but when it go above 7 grand the check engine light comes on with tps code. So i think i do need a gasket ima try that first and see if that helps</TD></TR></TABLE>
ok i understand now. yeah u will need a gasket and also tps adjustment, is your idel rpm normal ?
Old Mar 4, 2008 | 07:53 AM
Default Re: tps problem! Help (crazyguy)
ya normal so ima try that gasket and let ya know here in a few hours. Thanks for the help
Old Mar 7, 2008 | 06:34 AM
still comes on! so im going to replace it with my new one that should be comin here soon and ill let everyone know
Old Mar 7, 2008 | 07:15 AM
Blk00EJ8's Avatar
A CEL for your TPS at a certain RPM is not going to be fixed with a gasket. You're not going to get a CEL because there's no gasket there, even if it is, in fact, leaking air. Try replacing the TPS, put a gasket on anyway, and calibrate it properly. 0.45 volts on 0% throttle, 4.5 volts at WOT.
kornkid21792
May 12, 2010 10:06 PM
RacingShoeBox
Jun 12, 2006 06:37 PM
jwamp316
22
Feb 7, 2005 01:08 AM
Trbospnkr
May 8, 2003 11:49 PM
rasta420
Apr 22, 2003 01:02 PM
